Sony Ericsson / Sony : Software, Firmware and Drivers : MyPhoneExplorer 1.8 available !
On 2005-10-08 16:04:04, BlueQuill wrote:
Is it better than the opera mini?
Opera Mini is a browser... My Phone explorer is a mobile phone agent...a program to be installed on a pc which allows the pc to access your phone for file transfer, sync etc. like FMA
Posted: 2005-10-08 16:09:46
@stirlsilver: I think there was a bug in SE-Phones when all days of recurrent alarm are deactivated. Set the recurrent alarm on phone on some Days active and it should work.
Timestamp of sent messages. I said it very often and i will say it to you once more. This is NOT POSSIBLE. There is no way to fix that. MyPhoneExplorer saves the Timestamp of a send message if the message was sent with the MPE. But that is all i can do.
Regards FJ
Posted: 2005-10-08 17:06:34
Time on phone: GMT+12.00/Summertime
Global Atom Time: GMT+12.00/
Difference of 3600 seconds.
XP SP2 Date and Time Properties.
Under Date and Time tab: Current Time Zone - NZ Daylight Time
Under Time zone tab: GMT+12.00 Auckland, Wellington, Automatically adjust time for Daylight Savings, ticked.
Under Internet Time tab: time.windows.com
Dunno what else I can do??
Posted: 2005-10-09 01:38:21
Cheers, sorry about asking a question that was already discussed, I must have skipped over it when I was reading through the posts, my bad.
Posted: 2005-10-09 02:07:18
@zillertaler
Im using the english language.
Posted: 2005-10-09 16:15:38
@ryanbp: Please download the update, i've fixed some bugs
@carkitter: I've tried to set the timezone of my PC like yours and it worked perfectly, at the moment i don't know where i should search the error
Posted: 2005-10-10 01:31:57
Never mind, it's only a small issue.
I still think your program is superb.
Posted: 2005-10-10 11:18:40
@zillertaler
I added the following to the 'general' config. settings file:
CalendarView=0
that fixed it..!!!!!..
sweeet!
Under the Calendar view, the 'New Task' icon right next to "new appt.'; when u hover over it with ur cursor it displays it in Deutsch: Neue Aufgabe !!...
I do like the "upload Java app" feature!!!!! Also, MPE seems a bit faster now!....
One more, thing: could you implement a 'directory' tree under the Files section?!! on the left column!. that would b nice!
Posted: 2005-10-12 04:08:22
Thanks for report. In Vesion 1.2.12, which is at the moment online i fixed also your Bug with the calendar.
Directorytree will be added in the next version
Posted: 2005-10-12 12:31:13
Just downloaded it today....works brilliantly with my new K750i....I had installed FMA prior to this, and faced some issues in getting it to connect .....but got it right the first time with this wonderful lil program ...thanks a ton @zillertale....looking forward to the next version
Posted: 2005-10-12 17:41:17
