Sony Ericsson / Sony : Software, Firmware and Drivers : MyPhoneExplorer 1.8 available !
Salut,comment on fait si on ne se souvient pas de son mot de passe???
Posted: 2009-12-08 21:37:55
Please post in english
And what phone do you have?
Posted: 2009-12-08 21:39:17
My english is very bad sorry
I have two telephone a W910i and a W580i and for two it ask me a password.
But i don't have password.
Posted: 2009-12-08 21:56:48
It's strange it asks you for a password. The default password is, in
phones, 0000.
Posted: 2009-12-08 22:09:28
jus downloaded and installed the latest version of MyPhoneExplorer but not able to get it to work with either W880 or C510...it says Phone not found when i click on connect button....am i doing somethin wrong? oh am runnin Win 7 if that helps
Posted: 2009-12-14 11:07:41
assuming that you are using bluetooth connection....
try to pair your phone first with the pc (not necessary but i would recommend it), then launch mpe and search for device (it will take sometimes), click your device in the popup windows and connect....
btw i'm using win 7 too and mpe works perfectly
Posted: 2009-12-14 11:46:36
sorry for not mentioning before...not using BT
Posted: 2009-12-14 11:52:37
owh ok...
uninstall mpe, install SE PC Suite or Gordon's Gate Driver (ggsetup-2.2.0.5 usb driver, google it) or both, then reinstall mpe. once you connected your phone via the usb cable, mpe will automatically detect your phone and at the same time the windows autoplay will popup. you can either use the mpe popup or the autoplay to connect...
Posted: 2009-12-14 15:22:57
thanks @mallaccra will try that
Posted: 2009-12-14 16:22:53
Thanks, gonna give this a whirl.
Chris.
Posted: 2010-01-07 19:35:10
