Sony Ericsson / Sony : Accessories : Memory Stick FAQ
< Esato Forum Index > Sony Ericsson / Sony > Accessories > Memory Stick FAQ Bookmark topic
Page <  123 ... 171819 ... 212223>
strizlow800 Posts: > 500
The phone will work OK. You will lose speed in reading tracks in the media player only
Posted: 2008-07-08 07:39:34
abubakar Posts: 109
why is it so hard to know the capacity a phone can take? you'll get different capacities from different sources. initially i heard my p990 had a 2 gig cap. now i hear its 4! i've even seen a site that said 8! cant the phone manufacturers give the capacities on thier web sites?
Posted: 2008-08-15 00:44:00
masseur Posts: > 500
the trouble is that capacities are given by SE at time of launch based on what is available at that time.
however these days you can be sure that SE are not placing artificial limits on their phones so if it supports 4gb you can be sure it will support 8gb and larger
most phones support fat32 and therefore fit the above category but only a few low end models still support only fat16 and therefore only support up to 2gb
Posted: 2008-08-15 00:50:17
max_wedge Posts: > 500
The most common limit of fat16 partitions is 2GB. P910 uses fat16 hence the 2GB limit. However Windows xp can format fat16 partitions to 4GB, but will only be readable by other WinXP devices. This may be where the confusion comes from.
EDIT: Oops, I just noticed he was talking about P990 In that case it will without a doubt support 4GB (and higher)
K800 can use up to 32GB (the memory addressing limit of the memorystick architecture). As far as speed goes there is no difference. What some notice as "slowness" is simply the fact more filenames need to be read into memory. Example, an 8GB (my K800 uses 8GB currently) card may contain say 5GB of music in one folder (as is the case in my example). It will take the phone a considerably longer time to load the list of files into memory compared to a folder containing only 1GB of files. This is true regardless of the total size of the card.
As far as performance goes there is no difference. Equivalent videos for example play just as smoothly on a 2GB card compared to a 8GB card.
BTW, 8GB card memory size is read correctly on my K800.
Tricks and Tricks for K800 File System Tweaks for K750
[ This Message was edited by: max_wedge on 2008-08-15 09:44 ]
Posted: 2008-08-15 10:41:06
croatia Posts: > 500
Does k850i can take new micro sdhc 12 or 16gb?anybody?
Posted: 2008-08-20 10:31:36
Yes, without a question of a doubt
Posted: 2008-08-20 12:01:43
hussain@950i Posts: 4
Hi friends ,
this is hussain from india
i just want to know if we can extend the memory for w950i
Posted: 2008-08-21 11:52:48
The W950 has no card slot, so your stuck with 4GB
Posted: 2008-08-21 15:53:55
@max_wedge
do have sugesions how to improve the video quality on w950i ?
Posted: 2008-08-22 09:16:03
Nixxi Posts: 51
I just bought a sony m2 for my k800. And it sucks. File transfer is so slow. But I've only tried this using file transfer with my phone connected to the USB. I havent tried putting it into a card reader though.
Will it make a difference?
Posted: 2008-08-27 19:40:36
