Sony Ericsson / Sony : Accessories : Memory Stick FAQ
< Esato Forum Index > Sony Ericsson / Sony > Accessories > Memory Stick FAQ Bookmark topic
Page <  123, 4 ... 212223>
masseur Posts: > 500
I can only tell you what I and my son got in our box.
but also you need only look at the K750 product pages where you find the following image of a 64mb duo and the text describing it as such.
In fact the only time I have seen anything less than 128mb as a PRO duo is the 32mb card that came with the P910
Posted: 2006-02-11 19:00:11
whizkidd Posts: > 500
masseur, i'm a bit surprised!
why would the k750 come with a memory stick duo when it doesnt support it??
Wierd!!
And it comes inserted in the phone right?
Edit:
Ah now i got it!!
I almost had a psychic girlfriend, thankfully, she left me before we met.
[ This Message was edited by: whizkidd on 2006-02-11 18:06 ]
Posted: 2006-02-11 19:03:24
perhaps there is a significant point missing in this FAQ
products that are compatible with memory stick PRO duo are backwards compatible with memory stick duo
hence the K750 quite happily uses the supplied 64mb memory stick duo
edit: ah! I see you got it and it just shows that a FAQ like this is a real neccessity given the confusion over memory sticks!
reviews: i-mate V800 K700
[ This Message was edited by: masseur on 2006-02-11 18:12 ]
Posted: 2006-02-11 19:06:03
And i had always thot mem stick pros cant be used in devices supporting mem stick pros..
What a glaring ommission...
I'm surprised no one noticed it!
Posted: 2006-02-11 19:12:13
*Jojo* Posts: > 500
OK . . . sorry for the confusion back there mates . . . I will still meet my potential seller later . . . will insert his 64 MB stick to my P800 if it can detect the contents then it's a go for me . . . but if doesn't . . . I'll advise that guy to visit Esato and READ thoroughly Whizkidd's Thread - Memory Stick FAQ ! Thanks, Masseur and Whiz!
Posted: 2006-02-11 19:19:12
Ok I just grabbed my sons K750 64mb stick and my own P800
as you can see, in storage manager it shows as 61.6mb, pretty much as expected
Posted: 2006-02-11 19:28:37
*Jojo* Posts: > 500
WOWOWEE . . . that's a Real Time report for Masseur ! OK, me convinced now . . . . . what if you insert a PRO Duo stick mate . . . can it still be detected by your P800 I was surprised that you still have your P800 up till now, is your T68i still there? Thanks!
Posted: 2006-02-11 19:36:29
if I insert a PRO duo then it is neither recognised, nor is an error issued, it is simply ignored... again as expected
Posted: 2006-02-11 19:40:22
So the conclusion is:
1: Memory Stick Duo CAN be used on the K750 and above but will be limited to 128mb.
2: Memory Stick PRO duo cannot be used on the P800 (and the P900 AND THE s700). We all knew that.
3:Sony needs to be kicked on their butt for making things sooo confusing!!
Jojo, if your seller is selling a memory stick pro duo, it wont work on the P8.
bUT IF IT IS A NORMAL MEM STICK, IT SURE WILL!
Posted: 2006-02-11 19:41:54
*Jojo* Posts: > 500
@masseur - Thanks!
@whiz - I agree mate! makes so confusing cards Unlike with Nokia . . .et al, cards on 3650/3660/9210/9210i/6600/6230 etc. can be interchanged . . . not with the latest releases though as it is already supported by Reduced Sized Memory Cards !
Posted: 2006-02-11 19:48:12
