Sony Ericsson / Sony : Accessories : Memory Stick FAQ
< Esato Forum Index > Sony Ericsson / Sony > Accessories > Memory Stick FAQ Bookmark topic
Page <  123, 456 ... 212223>
maryus51 Posts: 112
Is this card reader supporting Memory Stick Pro Duos ? ... just see the pic.
Posted: 2006-07-20 08:48:32
max_wedge Posts: > 500
On 2006-07-07 19:21:06, joaobus wrote:
I have recently purchased a SE S700i, it originally came with a Mem Stick Duo with 32 MB, the card says Magic Gate also. Im looking fwd getting a new Mem Stick for 2G, so im wondering , will it be accepted on my phone??. If not, what`s the max capacity mem sitck i can get for it!?!?...
Thanx for the help!
No it won't. S700 max capacity is 128MB memory stick duo only (not compatible with any card that says "pro")
Kam27Quote:
@bustamo - Try formatting the memory card in your phone cos windows format system is totally different from that of the SE phones. I believe this should work. ( Insert into ur phone and format, ignore the shown error msg)
Actually, windows will format a 128MB memory stick using FAT, funnily enough, the exact same file system used by the S700 to format external memory. All SE phones use FAT or FAT32 for external memory. I format my memory with the pc and rarely use the phone.
When you post, check out your facts or make it clear you are posting an assumption only Computers and Phones are not as disparate as you have assumed. They have much in common.
Posted: 2006-07-20 15:38:21
biblebasher Posts: 17
thanks alot thats very helpful
Posted: 2006-07-22 18:23:15
happykhan Posts: 185
I want to buy a 1Gb MS Duo
I've heard that using 512 or 1Gb Memory Sticks on K750 will lead into high battery usage and the phone will very often hang.
Is it true?
Can anyone please confirm this(OR deny it)?
Posted: 2006-08-12 23:11:38
nah, it's complete bolloocks. Many peeps are using 1 and 2GB without any probs. I myself have used a 512MB for several months and my phone doesn't crash, period.
Posted: 2006-08-13 02:12:42
rrojas260 Posts: > 500
@maryus51
Yes, it works with MSD
Posted: 2006-08-13 02:14:55
whizkidd Posts: > 500
So folks, can I add the entry "More memory does not mean a sluggish phone" on the first page?
Posted: 2006-08-14 11:09:00
cletus141 Posts: 119
Does size of card and High Speed (or Ultra II in Sandisk) have any relationship to phone operation speed and/or battery usage?
I thought that I'd read somewhere that the faster sticks eat less battery and I'm considering upping my 2gb Sony MS Pro Duo High Speed to a 4GB stick for my w800.
For the record, I've noticed no appreciable sluggishness in my phone since going to the 2GB from the 64 mB card I had.
Thanks,
chris
Posted: 2006-08-16 01:02:42
Do it
Posted: 2006-08-16 07:01:04
Julidzg Posts: 23
Does the 4gb mspd works on W800, 'cause i've read of anyone who has it on the phone. I'm thinking of buying one but i have to be shure it's going to work on my w800. Also i'd like to know the best online deals on a genuine 4gb MSPD
Posted: 2006-08-16 08:13:18
