Sony Ericsson / Sony : Software, Firmware and Drivers : K800 Firmware Overview
< Esato Forum Index > Sony Ericsson / Sony > Software, Firmware and Drivers > K800 Firmware Overview Bookmark topic
Page <  123, 4 ... 453454455>
jcwhite_uk Posts: > 500
I think they have done that so you know it is doing something. The W800 takes ages to view a photo and sometimes it seem like it isnt loading.
Posted: 2006-07-03 23:06:33
SE-Naz Posts: > 500
@jcwhite_uk
Does that happen on your phone too???
Im not bothered if it does it.... all I dont want is if it only happens to me... then I have a faulty phone and would have to replace it.
Cheers
ENJOY
Posted: 2006-07-03 23:08:27
It happens to me. I think it is just se's way of showing us it is doing something.
Posted: 2006-07-03 23:15:44
SE-Naz Posts: > 500
@jcwhite_uk
Thnaks for confirming..... It doesnt bother me actually. There was a Nokia phone that I had little while back that did that.... Cant remeber which modeil.... So im aware of it..... Just wondered if mine was the only one.....
Thanks again
Cheers
ENJOY
Posted: 2006-07-03 23:18:34
alchang Posts: 7
I've got firmware version R1BA021 on a K790i.
Is anyone running a newer version on a K790(a/c/i)?
Posted: 2006-07-04 01:08:50
Paul_s Posts: 67
@SE-Naz, it does it on my phone too, it's like an image loading on a webpage page, but it's good coz you can scroll through the pictures qucikly, and just wait if you wanna see one properly, well done SE
Posted: 2006-07-04 10:40:38
SE-Naz Posts: > 500
@Paul_s
Thanks for confirming. I also did notice that you can go through the pictures mutch quickly like this. On the W810i, you had to wait for the images to come up before you could start looking at them.
Cheers
ENJOY
Posted: 2006-07-04 10:48:15
Aldrew Posts: 283
Right bugs, on R1BC001 O2 customisation.
Radio- has a beeping sound (someone, said it's like morse code, and I think this is a good way of descriding it)
Screen- Flashes white when going from sceen saver to sleep mode.
Posted: 2006-07-04 13:31:08
loomx63 Posts: 3
Mines R1CD001 its on three.
Anyway to debrand yet? how long do you reckon it will take?
Posted: 2006-07-04 15:23:11
voda_jon Posts: > 500
@ aldrew... the white screen issue is present on the Voda branded ones as well... not sure if its a bug or jus a by product of the firmware... either way it doesnt bother me...
Posted: 2006-07-04 22:40:56
