Sony Ericsson / Sony : Tips and tricks : Sony Ericsson K800i Tip And Tricks
< Esato Forum Index > Sony Ericsson / Sony > Tips and tricks > Sony Ericsson K800i Tip And Tricks Bookmark topic
Page <  123 ... 212223
altemyr Posts: > 500
Exactly, no problems at all with 4GB. What I have heard, it supports 8GB as well, even though there is a bug in the function that reports free memory, which only thinks it's 4GB. There are no such problems with 4GB though.
Posted: 2008-01-21 13:55:47
bass2rez Posts: 2
I am now running a 4GB M2 card and there is a fairly serious problem if you are running the original firmware (R1CB001), as I am.
The Java engine does not seem to be able to properly handle a 4GB memory card. Any applications I had installed on the memory card (after I copied the contents of my 2GB card to my 4GB card via a USB pc connection) fail when you try to start them, and you cannot install any java games or applications on the 4GB memory card.
I got round this by transferring the applications installed on the 2GB card to the internal phone memory using the menu option (More -> Move to Phone) and running Java apps and games from there, and just using the 4GB card for music and photos.
I do not know if this issue has been corrected on subsequent firmware updates, but I am unwilling to try an update as I want to keep all my SMS messages intact, and I read conflicting reports on whether upgrading the firmware deletes all SMS messages that are stored. Is anyone able to reliably state whether SMS messages are deleted during a firmware update?
[ This Message was edited by: bass2rez on 2008-03-16 22:34 ]
Posted: 2008-03-16 23:32:51
max_wedge Posts: > 500
messages are not deleted when you do a SEUS update.
You can also use MyPhoneExplorer (or even SE PC Suite) to backup messages to the computer.
However I'd be surprised if the JAVA engine cannot handle 4GB cards. I would try formatting the memcard first. JAVA really doesn't know or care what size memory is. It uses an API to access the memory card so it's only using the phone's own memory addressing system. If JAVA couldn't write to the card then neither could the phone imo.
File System Tweaks for the K750 K750 Tricks
K800 Tips and Themes
Max's K800 Page
[ This Message was edited by: max_wedge on 2008-03-17 07:19 ]
[ This Message was edited by: max_wedge on 2008-03-17 07:22 ]
Posted: 2008-03-17 08:18:09
centur Posts: > 500
On 2008-03-16 23:32:51, bass2rez wrote:...
Update your phone with SEUS: http://www.sonyericsson.com/d[....]e_Service_Setup-2.7.9.14-1.exe
Then format your 4GB M2 only FAT32.
On my K800@K810 R6BC002 4GB Sony M2 work fine and faster when compare with my old 1 GB Sony M2.
Photos with date and time save 6 s. ( with my old 1 GB Sony M2 -> 10 s. ) , without date and time 3 s.
Open video player with 3 GB videos for 7 s.
Posted: 2008-03-17 08:22:34
bass2rez Posts: 2
Thanks for that, Max. Perhaps I'll feel brave enough to try it then.
So, those of you with a 4GB M2 card can install and use apps on the 4GB card? I wonder why it fails on mine then? I did format the card via the PC cable as FAT32, by the way. Perhaps a newer firmware is the answer.
Posted: 2008-03-18 14:44:51
guyfreelance Posts: 30
I'ii try on my 2gb m2 it maybe faster
Posted: 2008-06-24 14:38:32
Xaviat Posts: 2
If you have a Notebook with bluetooth functionality you can install the SE software and control the mouse movements, mouse clicks etc with the K800 joystick. You can also play music/movies directly from your phone onto the computer...
I had fun with this while my gf was using the notebook and she thought it was possesed
Have fun...
[ This Message was edited by: Xaviat on 2008-07-18 06:36 ]
Posted: 2008-07-18 07:35:38
littledue565 Posts: 20
You can view media files on the PS3 with bluetooth
Posted: 2008-08-18 21:40:02
Nixxi Posts: 51
On 2007-12-16 00:24:22, SaLiH wrote:
I have one question, and I'm sure some of you who have 2 GB M2+K800i know the answer.
Well, I have K800i, and 1 GB M2 Sandisk memory card. I'm planing to buy 2 GB M2, I know that K800i supports it, but I have one doubt. Will my phone work slower with it, compared to how it works with 1 GB card?
Thanks in advance!
I have the 2gb m2 with my k800 and it works fine.
Posted: 2008-08-28 13:12:48
SirJ Posts: 7
On 2007-03-01 07:50:25, altemyr wrote:
As I already stated in my very first post to Esato in January 21, 2002, this code, > * and phones since the beginning of times, or at least since the first model ever released from Ericsson. It's a nice tradition from Ericsson that SonyEricson has continued, and it is no more very "hidden", since everyone knows about it. It is more like an extra protection of this menu in order not to access it accidentally. The code has become a standard for all phones, like the code *#06# has become a standard for almost all mobile phones for displaying the IMEI code.
When you press the key sequence, or move the joystick lef/right, just ignore whatever pops up or is displayed on the screen, just continue with the key sequence, > * [unquote]
Since I set calculator on the joystick's right click - no more Service menu is accessible. So for those who can't access it I recommend to register off all links from the joystick.
[ This Message was edited by: SirJ on 2013-12-07 10:31 ]
Posted: 2013-12-07 11:22:32
