Sony Ericsson / Sony : GPRS, WAP, MMS and Email setup : A Guide to get Gmail working on k800i (Send/Rec)
< Esato Forum Index > Sony Ericsson / Sony > GPRS, WAP, MMS and Email setup > A Guide to get Gmail working on k800i (Send/Rec) Bookmark topic
Page <  123 ... , 101112>
siksik6 Posts: 20
Thanks for the tips guys, working great on my K810i.
I was having problems sending, until I put in my username and password for outgoing, now all is fine. Thanks especially to Chrisbpr for the tip about subjects only, otherwise the mails just dissappear each time you do a send/receive.
Cheers!!
M
[ This Message was edited by: siksik6 on 2007-08-23 20:02 ]
Posted: 2007-08-23 21:01:34
blebon Posts: 1
I cant enter my email address as username since i cant put the . sign I have a K510i
Posted: 2007-10-13 20:38:20
Aivar Posts: > 500
On 2007-08-10 20:36:10, Gcane93 wrote:
Try the setting below, it worked on my K800i.
Connect: GPRS
Email address: username@gmail.com
Protocol: Pop3
Incoming server: pop.gmail.com
Username: username@gmail.com
Password: *****
Outgoing server: smtp.gmail.com
Now go to Advanced setting:
Encrytiption - Incoming: SSL
- Outgoing: TLs
Outgoing username: username@gmail.com
Outgoing password: *****
Incoming Port: 995
Outgoing port: 25 or 465 (mine works on 25)
Good luck. I have the TMO USA T-Mobile Web.
Do those figures about Gmail setup work everywhere and in every SE phone?
Posted: 2008-06-20 12:34:57
Mon1018 Posts: 15
I got the information.
Thanks for sharing.
Congratulations!!
Posted: 2008-07-15 14:51:38
dennevhyn_31 Posts: > 500
I also tried configuring my Gmail account on my Sony Ericsson K800i but it is not working. I believe I entered and configured the right settings but still it is not working. I will actually start to connect and find the server but in the end, it will just say "Server not found." I am actually from the Philippines. We have several network providers here like Smart and Globe. I actually tried both but neither of them worked. Gmail only works on my phone if I'm gonna use the Gmail app that I downloaded. It only works on Smart but not on Globe. I think the reason why it is not working is because of our network providers here. Anyone from the Philippines here that is able to make Gmail work on Sony Ericsson K800i?
Posted: 2008-08-13 11:20:48
chrisnewman Posts: 34
Good luck, I got it working using the SE support tool
"Experience is the name everyone gives to their mistakes." — Oscar Wilde
[ This Message was edited by: chrisnewman on 2008-08-13 13:00 ]
Posted: 2008-08-13 13:15:07
naveedaziz83 Posts: > 500
gmail on my k800i r8bf003 not working ... below are my settings
Connect Using: 02 prepay gprs
email address: me@gmail.com
connection type: pop3
incoming server: pop.googlemail.com
username: me@gmail.com
password: *****
outgoing server: smtp.googlemail.com
Advacned Settings:
your name: left unchanged
signature: unchanged
download s&r: unchanged
check interval: off
push email: greyed out
Allow connection: home connection
copy outgoing: off
encryption:TLS/SSL
incoming server: SSL
outgoing server: SSL
outgoing username: me@gmail.com
password: ****
incoming port: 995
outgoing port: 465
I have also checked security -> certificates and it shows tht i do have the thawte premium server CA
Can sum1 plz help .. will really appreciate it ...
thanx
Posted: 2008-08-13 15:26:50
At last, mine is working now. I thought that I'm doing the wrong configuration but I found out that I just need to select a different Internet profile on my phone.
Posted: 2008-08-16 11:53:58
@naveedaziz83: Actually, we have the same settings and mine is working. I think you can try to select a different Internet profile. Does O2 provide several Internet settings or data accounts?
[ This Message was edited by: dennevhyn_31 on 2008-08-19 06:19 ]
Posted: 2008-08-16 11:57:26
password: *****
Advacned Settings:
check interval: off
copy outgoing: off
encryption:TLS/SSL
password: ****
incoming port: 995
outgoing port: 465
thanx
well there is o2 prepay wap
and o2 wap gprs
are you using o2 prepay or the contract one
Posted: 2008-08-16 13:22:32
