Sony Ericsson / Sony : Software, Firmware and Drivers : K610 & V630 Firmware Overview
< Esato Forum Index > Sony Ericsson / Sony > Software, Firmware and Drivers > K610 & V630 Firmware Overview Bookmark topic
Page <  123 ... 10, 111213>
Shadow_One Posts: 2
Hi there...i have a SE V630i buied from Vodafone Romania (i am from Romania). I have R1ED001 version installed and when i try to install a newer version using SEUS, it says me that i have the last version. Can i update to a newer version? How?
What exactly is CID49, CID50, CID51 and CID52?
Can anyone post me a detailed tutorial of how can i update my software version?
Thanks...
Posted: 2007-04-02 22:54:17
takot Posts: 2
hi was just wondering how you remove the sim card on this phone, because i am struggerling big time
Thanks for any help..
Posted: 2007-04-08 16:11:20
carkitter Posts: > 500
I have a V630i on R1ED001 and a PictBridge compatible printer. Does anyone know how to use PictBridge with V630i?
Posted: 2007-04-10 15:54:13
hawkwind Posts: 11
Hi, the V630i on Vodafoneuk has just updated my firmware to R1Jc002 with the sony ericsson updater.
Posted: 2007-05-01 15:05:58
prince_inc Posts: 59
any news about R1KC001?
Posted: 2007-05-01 19:58:42
mob453 Posts: 207
Got a huge problem with the latest three uk firmware. It does not allow you to disable instant viewer. The option to disable has been removed on the latest version. The viewer itself has not been removed.
Posted: 2007-05-04 20:51:00
MrZippy Posts: 151
Odd as I did a SEUS update and it was removed, but then again I had turned off anyway.
Posted: 2007-05-16 21:34:10
MrZippy Posts: 151
3-UK Customisation Changes
I had previously updated to R1JE001 via SEUS, but this weekend my phone died so I had to send away via a 3-Store to get fixed...
On return I still have R1JE001 but there are 3 changes:
1. 3-Player is gone from the Main Menu, now the normal Music Player
2. The EMS animations (Add Item > Animations) have changed to be the same as the ones on the walkman phones.
3. The Music Internet button (next to the left soft button) now goes straight to the internet, previously the R1JE001 SEUS update made it have a 2 second pause before you launched the internet.
Point 3 is very annoying that this fix is now broken.
[ This Message was edited by: MrZippy on 2007-05-16 20:41 ]
Posted: 2007-05-16 21:39:07
obakesan Posts: 198
Hi,
re: point 3. the "music" button on three se phones is just the normal internet button branded with headphones. as such you should be able to point it to the music page (or any other) by changing the homepage setting for the internet profile. settings -connectivity , internet settings, internet profiles, select 3browse locked, more - advanced, change homepage.
cheers.
Posted: 2007-05-18 00:20:55
MrZippy Posts: 151
On 2007-05-18 00:20:55, obakesan wrote:
Hi,
cheers.
Before I had the full re-flash at a service centre this button launched the 3 player java app, which basically wrapped to the 3 music store on their wap site... On the full flash 3-viewer is no longer on the main menu....
Anyway as the profile is locked I created a new one, changed then homepage and set the page to google... It did not work, I assume even thought the 3-player is removed from the main menu some sort of hard coding sets this button to the 3 music store.
Posted: 2007-05-19 14:17:42
