Sony Ericsson / Sony : Software, Firmware and Drivers : K610 & V630 Firmware Overview
< Esato Forum Index > Sony Ericsson / Sony > Software, Firmware and Drivers > K610 & V630 Firmware Overview Bookmark topic
Page <  123 ... 8910, 111213>
holmern Posts: 2
Not sure if this has been answered already but I'll ask anyways.
I live in the US and bought a euro version of K610i. Turns out it is has a australian or british planet 3 network thing installed on it. Tried updating firmware from wotanserver to debrand it, but I still have several "3" menu options and still cant chose the languages I selected from wotanserver. Is there any way I can get rid of this? Tried master reset after I did the firmware upgrade as well, but nothing helps. And now the backlight wont come one when I use it. Have to turn it off and on again for the backlight to come on.
Thanks
[ This Message was edited by: holmern on 2007-01-26 03:21 ]
Posted: 2007-01-25 23:55:30
holmern Posts: 2
Just disregard my above question. I tried flashing it with an older firmware and then used SEUS to upgrade that one to the newest Europe 4 firmware.. that finally took away all the remnants of Planet 3.
Posted: 2007-01-26 05:41:20
tomycs Posts: 5
On 2007-01-25 19:01:44, eggster2k wrote:
that's all i can suggest really, unless you wait for orange to release a new one. What firmware version are you using now?
so i can't put any other firmware on it... just orange... and if i would unbrand it??
firmware version: R1CB001
Posted: 2007-01-26 17:03:44
tomycs Posts: 5
is there any software for PC with which i could upgrade my phone??(with DCU-60 cable)
Posted: 2007-01-28 16:43:54
Beltxo Posts: 24
Anyboyd knows if RGB001 is available for v630?
Posted: 2007-01-28 18:56:50
Mads_o Posts: 3
I'm in the UK on a K610i Orange branded company phone (so I probably shouldn't upgrade through Wotan).
I'm thinking there must be an error in SEUS, because my software is: R1CB001
That seems to be VERY old.
Can anyone confirm that this is indeed the latest software for UK Orange branded K610i phones?
Thanks!
[ This Message was edited by: Mads_o on 2007-02-08 00:49 ]
Posted: 2007-02-08 01:38:36
dapostolidis Posts: 18
Having K610i with R1GB001 unbranded firmware, apart from the video preview bug i also noticed the following: Call list has problem, not recording may entries, and some times the green volume "balls" during music and video play back don't appear. Really dissapointed. Will this new firmware version be on SEUS soon? Does it fix the above mentioned bugs?
Posted: 2007-02-08 22:09:36
ok, problem with call list sorted with clearing it up from options. What happened was after an unanswered call, the activity box would appear but displaying shortcuts instead of missed calls. And didnt register anything (incoming, outgoing calls etc), till it was cleared up. Strange.
Posted: 2007-02-08 23:53:23
aremaboy Posts: > 500
R1JC002 fixes these bugs.
Posted: 2007-02-09 00:37:00
xodeus Posts: 55
Yes, you can use SEUS or wotanserver.com
Posted: 2007-02-10 15:40:56
