Sony Ericsson / Sony : Software, Firmware and Drivers : Best free instant messenger apps for mobiles
Yeah but generally, the amount of data used is very low.
Posted: 2006-12-14 17:41:43
which of those can disable proxy or can use port 8080?
Posted: 2006-12-14 17:42:30
I dont know if I understand your question but I think itīs more upto the network provider youīre using and if they allow connections over all tcp ports, than the application itself.
Jargong, in this early beta, is using :8080 for some datatransfers and also some other tcp ports. People with network providers that blocked those ports cant use Jargong right now, but itīll be fixed in upcoming versions.
Proxys is also upto the network provider, in some network you need them and in some you dont. I prefer not using it.
Good luck!
/Robert
robert@jargong.com
Posted: 2006-12-15 17:42:09
i can bet: mig33 is much faster than reporo. reporo's GUI is good looking but complex and bulky(so is slow).mig33 is simple and fast. can you send free sms with that..?
Posted: 2006-12-15 21:37:51
mOrange update, interface (google so) n connection settings
Posted: 2006-12-17 22:28:07
Here in norway Telenor Mobile and Microsoft got togheter and made the first own Microsoft MSN live messenger for mobiles
Posted: 2006-12-18 04:07:43
Actually I think itīs the same solution from OZ Communications that 3 is using?
Good thing: 6 months for free.
Bad thing: After 1 june 2007 NOK 49 per month - a bit too expensive?
Anyway a step in the right direction!
/Robert
robert@jargong.com[ This Message was edited by: roope66 on 2006-12-18 17:24 ]
Posted: 2006-12-18 18:23:29
where do i get jargong?
Posted: 2006-12-18 22:24:54
Mmmm maybe
www.jargong.com
I
n
Posted: 2006-12-18 23:07:32
Thanks!
Still very early beta, but we decided to put it out on our site for the people that want to try it out, but if you know youīre a person thatīll be pissed off if it doesnīt work maybe you should wait a couple of more weeks before downloading.
Seems like it works for aprox 50% of the people downloading it, the others have various network problems caused by early code with no HTTP fallback (sorry about that), bad APN settings and operators blocking SocketConnections.
Try it if you want to. Just mail me if you need help. (and dont care about the photo functions in it, they will all make sense in the upcoming version..).
/Robert
robert@jargong.com
Posted: 2006-12-19 03:35:35
