Sony Ericsson / Sony : Technical : How I fixed my k800i joystick - Step-by-step with pics
< Esato Forum Index > Sony Ericsson / Sony > Technical > How I fixed my k800i joystick - Step-by-step with pics Bookmark topic
Page <  12345678>
whatsucka Posts: > 500
On 2007-03-26 23:10:29, trumpeter wrote:
Thanks, conzepth, I managed to fix my K750i joystick using your method. Nice one!
For anyone who's interested:
Remove battery
Undo the two flat screws and take of the back cover by gently prising the cover away from the sides with a very thin blade
Undo the two torx screws and remove the front cover in the same way
Take out the keypad and gently open out the keypad sensor
Pull off the joystick itself and then follow conzepth's instructions (I applied a hoover at this point, too)
When you put it back together, do so with the camera shutter open, to avoid squashing the shutter sensor
Sorry I didn't take any pictures. Then again, my phone's had a hard life and I didn't want you guys insulting it!
Best wishes, Neil
can u have some pictures how to fix it?? is it same as W800i??
Posted: 2007-03-27 04:37:54
lemmor08 Posts: 43
i do he exaxt method what conzepth says. by the way, w800i doesnt have any joystrick. right? so its not applicable for that thing
Posted: 2007-03-28 06:48:29
um, w800i DO have a joystick
Posted: 2007-03-28 07:59:22
seenu84 Posts: 1
Thanx a lot, this trick works
Posted: 2007-03-29 15:00:37
SHAHSANGEL Posts: 2
I'VE FOLLOWED YOUR PICS AND CLEANED MY K800i,IT WORKS GREAT THANKS ALOT WELL UP
Posted: 2007-03-30 01:25:16
lemmor08 Posts: 43
soti whatsucka... i tought that w800i is the same as w810i. maybe you cant do that trick for your phone because of a different syle...
Posted: 2007-03-30 02:41:21
Neo-Tech Posts: > 500
post a video conzepth
Posted: 2007-04-01 12:20:55
Maddreg Posts: 5
Thanx for guide, Conzepth!
I did it for 2 minutes, I used paperclip instead of scissors, and it really helped!
I don't understand people who are writing "oh, I would never do that to my phone, I don't want to scratch it, look at your keys, bla bla"... If your hands are growing from the right place, but not from ass, everithyng will be ok. Conzepth just described his method, which works. If you don't want to do it, then shut up and enjoy you "nice working" joystick.
Posted: 2007-04-02 23:14:13
exor Posts: 1
i did it too.!!!!
thanxx!
Posted: 2007-04-06 07:51:08
a1m80t Posts: 7
Good guide
i did a similar thing with my k750 except i used wd40 and a needle and it worked like a charm.
Also, for people who say they would never do this to that phone, I wonder if you guys will still have the same mentality when your joystick starts to really suck... and you don't have any warranty/ can’t afford to wait for them to fix it
Finally, you can always buy a new faceplate and voila, you have a "new phone"
Posted: 2007-04-13 21:42:50
Page <  12345678>
