Sony Ericsson / Sony : Technical : How I fixed my k800i joystick - Step-by-step with pics
< Esato Forum Index > Sony Ericsson / Sony > Technical > How I fixed my k800i joystick - Step-by-step with pics Bookmark topic
Page <  12345678>
skylineR35 Posts: 279
i dare not do that cause my K800 have no scratch at all.
but i got another method to help improve the joystick usability.
this is the method:
first get a 2mm thick double tape.
then cut it at the size of HPM70 hole. (same diameter with K800 joystick)
after cutting it as a circle nicely, stick it there, (but before clean it first)
and then for the top surface, use something like water or soft alcohol to remove the "stickiness" on the surface that you're pressing.
(theorically: this make the joystick fatter, thus improve its usability.)
so far, i got all positive comment, lots my friends told me that without using that, the joystick is worse. if anyone interested, i can post pics later.
Posted: 2007-07-24 13:25:23
PowerLee Posts: 344
If the phone is still under warranty ( 2 years in the U.K. ) why not just send it back for repair?
Posted: 2007-07-25 11:31:32
defiantbeast Posts: 257
Thank you this was very helpful
Posted: 2007-07-28 02:51:04
scotterillo Posts: 1
Ive just thought 'what the hell' and followed your tutorial, as my joystick wouldnt allow a down or right movement and can report as you stated, its as good as new now! Thank you. Ive been wondering for ages how to get in to clean it. I used an electrical screwdriver to prize off the plastic surround. Its also worth mentioning that when putting back together, its important to position the two lugs at the bottom of the plastic surround into place first and then lowering the top part into place until it snaps back into place. Cheers!
Posted: 2007-08-06 22:11:18
psp476 Posts: 83
Well I love my mobile, so I'd rather take it to a proffesional and spend some money then scratch/damage my mobile
O and try to get problems while your mobile is under warantee
Not that you can really choose but anyway
The gun does all the damage, but its the man behind it who decides to pull the trigger
[ This Message was edited by: psp476 on 2007-08-06 21:46 ]
[ This Message was edited by: psp476 on 2007-08-06 21:48 ]
Posted: 2007-08-06 22:44:29
shuyin1946 Posts: 22
By the way i have question how come the joystick get faulty so easilly? U use it hardly? Or its a curse?
Posted: 2007-08-12 18:50:10
je4nKO Posts: 1
Yeah,thank you.I did it right now,and it is f**kin working!
Posted: 2007-08-13 16:47:07
kaizerp900 Posts: 88
The joystick on mine was a bit unresponsive so just used your guide & seems to be working a treat.
Cheers
Posted: 2007-08-16 16:28:26
hanugro Posts: > 500
I give mine to service centre under warranty. They change the joystick switch (couldn't take photo since they need to claim it to SE) and it all well again under 3hr for free.
Edit: it is the fifth pic in the first page
Those who still got warranty is better to use it. It is our right anyway.
[ This Message was edited by: hanugro on 2007-08-16 17:45 ]
Posted: 2007-08-16 17:44:36
aldmo87 Posts: 1
I tried it, it worked beautifully, and there is no way to scratch your phone doing just use some super small scissors and you'll be fine.
Posted: 2007-08-18 05:28:26
Page <  12345678>
