Sony Ericsson / Sony : Technical : How I fixed my k800i joystick - Step-by-step with pics
< Esato Forum Index > Sony Ericsson / Sony > Technical > How I fixed my k800i joystick - Step-by-step with pics Bookmark topic
Page <  12345678>
hassanthedon Posts: 1
Thanks a lot man it works....
Posted: 2007-09-09 14:16:25
wtse Posts: 3
This is completely WRONG, Please everybody never try to do that and beleive me that is not going to help you at all !!!!
Posted: 2007-09-09 14:30:46
rally1998 Posts: 8
Why Not? Those JoySticks really end up pissing people off if they can't get them repaired..at least they have some hope of bringing sanity back into their life.
I nearly went mental when my K700i started doing it. My K700i keypad went dodgy, so stopped using it. I've since got a known working KeyPad, so am going to give this trick a try on my old phone.
Hope my K810i doesn't go the same way
Posted: 2007-09-13 01:32:01
kcng Posts: 27
The method described by the first poster does work. It's quite easy to take the cover off and adjust the four plates. My down direction joystick didn't work well (missed half the time). Now, after the fix, the down direction only misses 10% of the time. Have fun.
Posted: 2007-09-18 17:12:48
decay_zeit Posts: 401
fortunately my joystick haven't gone wrong even once after 11 months...i love my k800...
although i've already tried this method,didn't do it completely,i was just curious,so i pulled out the cover,interesting,lighting is more impressing without that cover keys
Posted: 2007-09-18 17:51:26
auszombie Posts: 1
Thanks conzepth for this great guide.
Although I haven't tried it (only got my phone for less than half a yr and it's still working fine), this method seems simple and practical, exactly what I'm looking for
Posted: 2007-09-21 05:24:53
skylineR35 Posts: 279
actually, i can do the first 4 process without the need of scissor.
just use your fingernail to open the cover gently....
then make sure there's no scratch made on the softkeypad and joystick cover.
then i just cleanup everything up there, and put all in (soft keypad) except the joystick cover. it's good now, althou it looks ugly.
but at least no scratch in my phone at its 8th month.
(like 1st poster pic number 2, after thorough cleaning at the area.)
Posted: 2007-11-16 03:01:30
ijaljail Posts: 14
It works guys..thnx for the tip.
if u scared scrathing the phone..just use paper clip,paper clip don't have sharp edges.
Posted: 2007-11-16 04:05:29
razec Posts: > 500
I fix SE joystick based phones by cleaning the module with a non-staining liquid(mixed it with an alcohol) that and later on sealing it around with something to prevent the dust to get inside it i've dont this 3 weeks ago up to now my joystick never becomes irresponsive
Posted: 2007-11-16 05:13:11
@ijaljail
actually nail also become handy because its not sharp and "you carry it everywhere"
i wonder how much is the joystick 'cap' price in SESC cause mine is no longer scratchless at the edge. anyone knows?
Posted: 2007-11-16 07:44:24
Page <  12345678>
