Sony Ericsson / Sony : Technical : How I fixed my k800i joystick - Step-by-step with pics
< Esato Forum Index > Sony Ericsson / Sony > Technical > How I fixed my k800i joystick - Step-by-step with pics Bookmark topic
Page <  12345678
RaikaKh Posts: 1
I tried it and it worked, but I agree it's a little risky.
It sucks when the joystick doesn't work properly, but thanks to this guide, it's working great now.
Thank you.
Posted: 2009-03-25 22:32:14
Thijs_Rallye Posts: 19
Thanks for conzepth! My joystick works like a charm again.
Only problem I have now is that I just bought a C905 to replace the K800 because of the worn joystick, which is working like new again .
Thanks!
grz Thijs
Posted: 2009-04-11 23:16:12
popdog2 Posts: 1
Just the tutorial I was looking for.
Works perfectly - my joystick was taking upto 20 attempts to move to the right in a menu but after following this tutorial it works 100% of the time! Thanks very much!!!
I had been thinking of getting a new phone but now i'll be keeping this until something more permanent goes wrong.
Thanks again!
Posted: 2010-04-21 12:19:02
whoisabdul Posts: 1
It worked for me, my K800 is a beautiful phone and I couldn't bear to replace her just because the joystick kept sticking... my own stupid fault for playing too many stupid games...
Thank you so much, it took all me all of 5 minutes to fix and the joystick is much more accurate when running the keyboard test (95% vs 50%)
Posted: 2010-04-24 23:09:57
James1000 Posts: 23
Is the K800 the successor to the K750?
Posted: 2010-05-25 02:35:14
altemyr Posts: > 500
In a way, yes. It's one of many in a long row of similar phone models, starting with T610 with built-in camera, radio, media player and big display. K700 is another model, with bigger display than before and with more internal memory. K750 was the first model that supported memory card (MemoryStick Duo).
K700i had the very same problem with worn-out joystick and I'm sorry so say, that like with the K700i, a malfunctioning joystick may not always be repaired by the method described in this thread. It may help a bit, but if the phone is taken care of by a SonyEricsson service center, the joystick contact mechanism will be soldered out and replaced by a new one. Furthermore, the method described here to remove the front with a pair of scissors actually breaks the front panel, since the spare part for the keyboard, which is mounted from the inside of the housing, comes in one single piece that shouldn't be taken apart.
[ This Message was edited by: altemyr on 2010-05-25 12:30 ]
Posted: 2010-05-25 13:25:02
strauts Posts: 180
and by the way, that k800 looks good, if you could to see my brothers k750(my first se) omg! No camera, no speakers, pure joystick,(i will try to fix it, now i know how to do that) skracthed.
And sorry about my english!
Posted: 2010-05-25 19:18:00
ceaser2008 Posts: > 500
This is the thread for which i registered here at ESATO because it required to login in order to see pics in the first post. That time i had k800i.
Later the cover was so loosen up that sometimes it would come out just like that.
Posted: 2010-05-26 10:40:55
GoodReader Posts: 1
Basics of getting to the joystick work for the K510i though the surround to joystick seems a bit more fiddly trying to replace as there are two off set plastic pins that need locating - took ages for my old fingers! Sadly though cleaning and tightening didn't make it work and I still can't get the joystick to select the main menu and navigate or navigate down the call list. Somehow its not making connections. Any further suggestions before I go to a repair centre would be appreciated. Thanks Goodreader
Posted: 2011-05-02 12:18:33
dunsane Posts: 1
The problem I had was that when I went down with the joystick it would often click, which is a kind of a problem when you scroll your contacts ... I skipped step 4, just done a clean and it works fine now ! Thanks a lot.
Posted: 2011-07-18 01:13:05
Page <  12345678
