Sony Ericsson / Sony : Accessories : GPS Enabler HGE-100
< Esato Forum Index > Sony Ericsson / Sony > Accessories > GPS Enabler HGE-100 Bookmark topic
Page <  123 ... 8, 91011>
darknoob Posts: > 500
guys, I have some questions before i may buy it:
1. Does it work well with K850? no problems?
2. Will it work with my operator's gps software?
Thanks..
Posted: 2008-02-27 11:53:52
Dart5 Posts: 168
Thanks..
1. It technically works OK, the problem I have is the software available for it make it of limited use. It comes with a couple of simple apps but neither can do the basic task of saving a waypoint and displaying it. I could also do with something that shows postion in OSGB rather then lat/lon. I gave up on the WayFinder demo SW, as it didn't seem to work and costs to download the maps. I probably wouldn't use it anyway. The headphones work well, but in hindsight I'd just buy HPM-82 (or similar) for less than half the cost and not bother with the GPS function until I get a phone with built in maps. There may be some other apps on the horizon (see previous posts here) which would improve it. However, I am just about to use mine when I go for a run to record the distance I've gone and listen to music while doing it - so it's not a total waste!
2. Couldn't say
Posted: 2008-02-27 12:32:56
Asok Posts: 2
Anyone using this with P1i? At first the P1i wasn't supported but it looks like it is now! I'm mostly interested in the Tracker software/function (gonna use running/cycling)
Posted: 2008-03-02 21:29:56
alex Posts: 156
Hi guys, would like to know those software for download under http://sehge100.com for wayfinder navigation and wayfinder earth is it free application or just a trial application which required to purchase in order to have full functions?
Posted: 2008-03-03 05:03:27
rvs Posts: 6
Is it possible share HGE-100 connectet to mobile via bluetooht?
It will a way to use it as "external" gps antenna... i.e. for use with a PDA...
Posted: 2008-05-06 15:08:51
Mr Miyagi Posts: > 500
am trying to establish if the connector for this device would allow me to plug in my charger too, since it it does not give you an option to plug in your charger, won't it drain the battery really fast when using the gps?
thanks
Posted: 2008-09-06 19:10:34
anyone?
Posted: 2008-09-06 22:18:39
yea g Posts: > 500
get a dual port charger its one with a pug on the back of it sawell
Posted: 2008-09-07 01:09:11
azza871 Posts: 36
hey guys, will this work with the g900? :S
its not on the compatible device list yet the software such as tracker are available for download on the SE website?
Posted: 2008-09-26 06:26:05
piflechien Posts: 138
I have never been able to get a fix with the satelites on the G900
Posted: 2008-10-01 23:33:51
