Sony Ericsson / Sony : Tips and tricks : Sony Ericsson Codes
< Esato Forum Index > Sony Ericsson / Sony > Tips and tricks > Sony Ericsson Codes Bookmark topic
Page <  123 ... , 111213>
gothenk Posts: 90
can anybody describe what "SIMLOCK" can do n can we use it like security, lock or unlock...
Posted: 2009-02-03 11:46:29
aquared29 Posts: > 500
ya same here what is simlock mean?
Posted: 2009-02-04 13:33:27
tranced Posts: > 500
you probably have to visit this thread
Sim locks question
Posted: 2009-02-04 13:40:55
bensalem Posts: 1
Thanks
This message was posted from a N70
Posted: 2009-02-04 13:41:21
saidforum Posts: 11
free advert for your reviews,site.weirdnews. etc send your advert to: saheedonline2010@yahoo.com
limited space available.the site commences operation soon
Posted: 2009-02-19 02:31:00
omkar Posts: 2
On 2007-06-18 15:43:25, axxxr wrote:
Having problems figuring out how to do stuff on your phone? well this may help!
Getting your IMEI (International Mobile Equipment Identity) Number: *#06#
Access Software version: > * < < * < *
Reach last dialed numbers: 0 then #
The Sony Ericsson Secret Menu screen: -> * <- <- * <- *
Change to Default Language (English): < 0 0 0 0 >
Info about SIMLOCK: < * * <
Opening phone without a SIM card: **04*0000*0000*0000# followed by on ‘Wrong Pin’ number
Posted: 2009-03-22 12:45:27
altemyr Posts: > 500
You should be careful when playing with this code. I'm not sure I remember this correctly, but I think the code **04* is for changing the phone's lock code, and the correct syntax is
**04*( old PIN )*( new PIN )*( new PIN again )#
So, if the phone's lock code has been left unchanged, i.e. 0000, nothing in particular happens if the code is typed, otherwise, the message "wrong pin" appears, and, if you try this 3 times in a row, the phone will become more or less permanently locked, it depends on brand and model whether it is bricked or not.
[ This Message was edited by: altemyr on 2009-03-23 13:25 ]
Posted: 2009-03-23 14:24:19
atinshah Posts: 1
[quote]
Access Software version: > * Reach last dialed numbers: 0 then #
The Sony Ericsson Secret Menu screen: -> * Change to Default Language (English):
Info about SIMLOCK: Opening phone without a SIM card: **04*0000*0000*0000# followed by on ‘Wrong Pin’ number
First 3 work just fine... but on 4th: The Sony Ericsson Secret Menu screen: -> * and what does info about SIMLOCK do?
just are move joystick L & R
Posted: 2009-03-23 15:49:34
kidkamel Posts: 16
Thanks for the codes! Very helpful
Posted: 2009-03-24 20:28:51
3_User Posts: 5
I think - is down and + is up on ut joystick/ navigation keys but im not sure
Posted: 2009-04-09 13:55:34
