General discussions : Non mobile discussion : Tell me what your pc has.
< Esato Forum Index > General discussions > Non mobile discussion > Tell me what your pc has. Bookmark topic
Page <  12345>
fatreg Posts: > 500
Like
OS: Mac OSX
CPU: Intel Core Duo
CPU ghz: 2.0
Ram: 1.5gb
ram ghz: 677MHz
Brand: APPLE!
Hard space: 250gb
and that stuff. - built in web cam, wifi, :bt: all behind a 20" screen
Posted: 2007-07-21 17:24:42
Luke-the-magic-man Posts: > 500
OS: mac os 10.5
CPU: intel core 2
CPU ghz: 2.33 ghz
Ram: 2gb
ram ghz: ?
Brand: Apple macbook pro
Hard space: 250gb internal
1tb external
2 printers
hardom kardon soundsticks 2
16 usb posrts
20" external screen
a fook load of usb plugin things
Posted: 2007-07-21 17:46:36
joebmc Posts: > 500
Heres mine (pretty old pc now)
OS: windows xp pro
CPU: athlon xp
CPU ghz: 2
Ram: 1 and a half gigs
ram ghz: 2700 (i think)
Brand: home made
Hard space: 2x 80 gb HD's
[ This Message was edited by: joebmc on 2007-07-21 18:18 ]
Posted: 2007-07-21 19:16:28
jcwhite_uk Posts: > 500
Windows XP Pro
AMD Athlon XP 2000
1600MHz
512MB
Custom made
1@80GB 1@40GB
Posted: 2007-07-21 19:22:33
Cycovision Posts: > 500
djtwistter wrote:
here is mine
OS:vista ultimate x64/Mac OS X x86 /lunix
CPU:intel pentium 4
CPU ghz:3.06GHZ
Ram:4gb
ram ghz:
Brand:custom made
Hard space:500gb
What are you using to run OSX on a custom built machine? VMWare, PearPC? You can't run OSX on a PC without a considerable amount of messing about!
Read my cartoon strips on B3ta.com
[ This Message was edited by: Cycovision on 2007-07-21 19:38 ]
Posted: 2007-07-21 20:35:27
djtwistter Posts: > 500
On 2007-07-21 20:35:27, Cycovision wrote:
djtwistter wrote:
here is mine
CPU:intel pentium 4
CPU ghz:3.06GHZ
Ram:4gb
ram ghz:
Brand:custom made
Hard space:500gb
well you can if you use easy bcd and i got soem help form this site http://forum.insanelymac.com
Posted: 2007-07-21 20:41:10
Cool! I didn't think EasyBCD could do that
Do you need any additional software?
Posted: 2007-07-21 20:57:35
well there is a couple of things you can do to make it smother like add the logo at the start for each one of them and then you could select which one you want to boot into but that takes soo much time to do and is allways buggy and you could also patch the kenal but it not worth it
Posted: 2007-07-21 21:02:54
paulbang Posts: 143
I downloaded a build or beta version (worked for some people) of leopard . . Well it uses only fat32 and luckily i found a old hdd with fat partitions, my pc specs were alright- it started the install and simply hanged- worked on some dvde's pc (lower config). Thus i'll wait for apple to release the final version
Posted: 2007-07-21 21:09:00
Unfortunately I don't have any decent working Intel machines to play with at the moment but I'll definitely give it a try when I do. Thanks for the tip
And before somebody says 'Why not just buy a mac', I already have one! It's a technical challenge that I want to know more about, that's all
Posted: 2007-07-21 21:17:44
Page <  12345>
