General discussions : Non mobile discussion : Tell me what your pc has.
< Esato Forum Index > General discussions > Non mobile discussion > Tell me what your pc has. Bookmark topic
Page <  12345>
djtwistter Posts: > 500
On 2007-07-21 21:09:00, paulbang wrote:
I downloaded a build or beta version (worked for some people) of leopard . . Well it uses only fat32 and luckily i found a old hdd with fat partitions, my pc specs were alright- it started the install and simply hanged- worked on some dvde's pc (lower config). Thus i'll wait for apple to release the final version
dude go on the site i posted eairler they will give you more help and btw its not realeasd by apple
Posted: 2007-07-21 21:21:35
paulbang Posts: 143
@dj will do once i get on a pc . . . It was gonna be either leopard or ubunto . . . Happy with xp/vista, too much software & data to risk a formatting so . . I'll try it on my neighbours pc haha yes that should do it. Thanks mate.
Posted: 2007-07-21 21:26:00
lol ahahahah poor newbies if you are with vista why dont you just use computer manager and create a partion on your harddrive and use that for the other os if you like it then tranfser evey thing to there it be better or much eayier use an external harddrive
Posted: 2007-07-21 21:39:43
amnesia Posts: > 500
Can't remember everything right now.
But
OS: XP sp2 /Vista Business
Processor: Intel E6400 (3.2Ghz stock not overclocked yet) Core2Duo
Ram: 2gb Extreme Gaming ram
HD: 200gb Maxtor + 250 gb seagate + 100 gb Samsung
Brand: Custom
Graphics: 2 x nVidia 7600 GTO Sli (512mb each)
Sound: JBL Creatures
Wifi
BT
10 USB
1 FW
etc..
All hooked up to a great 19'
Posted: 2007-07-21 22:22:53
Cycovision Posts: > 500
Aaaaah! I was wondering how you got round apple's hardware check!
That's why I asked about additional software. I tried hacked versions of OSX before with no joy. Looks like I'll have to try the newer versions when I get an Intel in next...
I kind of gave up and forgot about it until now
Read my cartoon strips on B3ta.com
[ This Message was edited by: Cycovision on 2007-07-21 21:27 ]
Posted: 2007-07-21 22:26:36
paulbang Posts: 143
Who's the newbie? Well i don't brag so don't need to justify
all my partitions are ntfs saving one which has just enough space for leopard- ntfs write is still in testing so don't expect that from apple. I will install it sometime though for kicks and then kick it out.
Posted: 2007-07-21 23:03:00
A L 3 X Posts: > 500
OS: Vista home premium
CPU:urr idk
CPU ghz: urr idk
Ram:1gig
ram ghz:idk
Brand:compaq
Hard space:80GB
Posted: 2007-07-21 23:17:35
*Jojo* Posts: > 500
OS: Over-Sex
CPU:Oral-B
CPU ghz: N/A
Ram:Tomato Paste/Raisins
ram ghz:N/A
Hard space:310 GB (D: 230 GB/ C: 80 GB)
Posted: 2007-07-22 03:41:13
clank Posts: > 500
@cyco
You dont need an Intel machine to run a hacked OS X. It runs just fine on amd if you dl an image which has been modded to run on both intel and amd, which is basically most of them.
Posted: 2007-07-22 07:52:02
Well, I must have very bad luck when it comes to downloading images then All of the ones I tried in the past would only run under PearPC!
Like I said though, I haven't tried it for a long time. Might have a go today
Posted: 2007-07-22 12:03:07
Page <  12345>
