Sony Ericsson / Sony : Software, Firmware and Drivers : Phone Flashing Tutorial XS++
< Esato Forum Index > Sony Ericsson / Sony > Software, Firmware and Drivers > Phone Flashing Tutorial XS++ Bookmark topic
Page <  123 ... 28, 293031>
victory_naz Posts: 1
I need help all i get is this
17:51:56| TURN OFF PHONE!
17:51:56| Hold 'C' button on phone and connect phone NOW.
17:51:56| You have 30 seconds...
17:51:56|
17:52:03| Baseband ID: 9900
17:52:03| Protocol Version: 3.1
17:52:03| Phone name detected!
17:52:03|
17:52:03| Profiling SEMC phone...
17:52:03| Platform: DB2020
17:52:03| OTP CID: 49
17:52:03| EROM CID: 52
17:52:03| EROM Color: Red
17:52:03| IMEI: 3
17:52:03| Phone ID: K790
17:52:03| Region: R
17:52:03| CDA: CDA102535/306 R19A
17:52:03| Firmware Version: R1JC002
17:52:03| EROM: R3A016
17:52:03| Ready for operation!
17:53:25| Sending db2020_cid01_prodid_p3j.bin...
17:53:25| Applet ID: 070129 0950 NGUCXC1250330_DB2020_PRODUCTIONIDLOADER_P3J
17:53:25| This is a PRODUCTION_ID loader
17:53:25|
17:53:25| Sending db2020_mem_patcher_cid52_r2a006.bin...
17:53:25| Applet ID: 061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0
17:53:25| This is a MEM_PATCHER loader
17:53:25|
17:53:25| Sending db2020_cid52red_flash_r2a005.bin...
17:53:26| Applet ID: 061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005
17:53:26| This is a FLASH loader
17:53:26| Now flashing firmware main...
17:53:26| Flashing c:\\documents and settings\\100368342\\desktop\\se\\se2\\k790_r8bf003_main_generic_ev_red53.mbn
17:53:26| Header type: BABE
17:53:26| 460 flashblocks
17:53:26| Binary acknowledge failed with: 89
17:53:26| Failed
17:53:26| Binary acknowledge failed with: 68
17:53:26| Command: Error 0x68
17:53:26| Failed sending flashblock 1. Returnvalue 0xD0022D00
17:53:26| Finishing flash
17:53:26| Binary acknowledge failed with: 02
17:53:26| Failed
17:53:26| Failed
Posted: 2009-06-24 23:56:13
tranced Posts: > 500
your phone is CID52 and you're trying to flash the MAIN with a CID53 one. get a CID52 one
17:52:03| IMEI: 3
17:52:03| Region: R
17:53:25|
17:53:25|
Posted: 2009-06-25 04:53:37
mrjulius Posts: > 500
Is this s0ftware can disable ur ph0ne?
Posted: 2009-06-25 05:05:44
well, if you make a mistake you can "disable" your phone. but most part of the time it is repairable
Posted: 2009-06-25 05:09:06
bitbucket Posts: 2
I want to unlock a SE W580i with firmware R8BE001. I'm locked to ATT/Cingular. I'm trying to be sure I understand what I'm doing before I get into too much trouble!
(1) If I take an R8BE001 .mbn file from the net. Drop it into SIMLockPatchGen.exe, and create a Remove_SIM_lock_W580_R8BE001.vkp. Can I then simply apply this patch to my phone??
- or -
(2) Must I first flash this downloaded .mbn file to my phone AND THEN apply the patch?
From the tutorials, I'm not clear if I can do the least disruptive action (option (1) only apply the patch).
(3) A related question... Is the .mbn file (R8BE001) already in the phone IDENTICAL to the one that I downloaded or is the one in the phone customized for my ATT phone?
Thanks...
Posted: 2009-06-25 19:50:25
first of all you cant use this program to patch the phone.
you must use either jdflasher + far manager or setool 2 lite.
Posted: 2009-06-25 21:02:55
bitbucket Posts: 2
That would explain why the "patch" function didn't work!
You actually answered a fourth question (that I didn't even ask yet). Assuming I were to use Setool_2_lite or JDflasher, can someone shed some light on questions (1), (2) and (3) from my previous post?
Thanks...
Posted: 2009-06-26 07:07:57
Skreppvin Posts: 2
[quote]
On 2007-09-30 09:28:00, strizlow800 wrote:
Hi to all. I have seen thet flashing CID52 phones has been very often nowadays, but many people are asking how to flash their phones and there is no such tutorial around the forum, so I decided to put one .
First of all I would like to tell the advantage (purpose) or meaning of flashing . Flashing the phone is procedure of putting new firmware (software) in the phone. There are many reasons to flash our phones. Firmware upgrade, solve software problems and bugs, convert our phones to some other model (most common is K800 to K810) and etc...
Flashing the firmware is done by changing the MAIN and the FS part of the firmware (while not touching the EROM and the GDFS) which makes the flashing easy procedure that can be done with the ordinal DCU60 USB cable (the cable you get with your sony ericsson phone) .
Once we know what flashing is, we can start preparing for the flashing procedure . To flash the phone means to change the MAIN and the FS part of the firmware, which means if you want to flash your phone with new one, you have to download it. Firmware and other stuff can be downloaded from here:
http://www.sek750i.pl
http://www.iprotebe.cz
These pages are free and registration is easy and fast.
First, download XS++ flashing program.
When you download MAIN and FS files for flashing, you need to download finalization files for your new firmware. There are MAAANY finalization files (a.k.a custom files or custpacks and etc...) sorted by the phone's firmware CDA numbers. To download the right one for you, you have to check your phone CDA. CDA can be checked from the service menu (>*
Posted: 2009-11-13 18:22:32
sagit524 Posts: 1
Hi...
i have a noob question... and actually i already try to search for the answer here but no luck.. so here i am seeking for a direct answer from the Guru.. hope somebody can help me...
i'm trying to flash a new FW to my k800i. but there are some information that i need to know.
1. i think i understand most of the step that given here. but somehow i just not clear, can i just take any FW that suitable for k800i (let say CID52) regradless of my current FW (mine is R1EG001/CDA102511/74/EROM R3A016(DB2020)/CID ??) ?
2. about this FW, im from Malaysia. which FW can i take? can i flash the Europe_1 ... or APAC or else? and what is the consequence if i take wrong vers of FW?
3 does my phone sim will be lock or not after i flashing the FW.
4. My current CDA is 102511? what is CDA actually? will it be changed after i upgrade my firmware?
Thanks
[ This Message was edited by: sagit524 on 2009-11-24 13:11 ]
Posted: 2009-11-24 14:05:25
wyneston Posts: 13
please help me...=(
I updated my Sony Ericsson P990i on SEUS...the update was on the installing process when suddenly the installation was interupted it says "the update was unsuccessful"...... when i tried to run SEUS again....there is no option to "update anyway" it only says you already have the lastest software...
My P990i is dead now.......when i turn on the phone it only display a black screen it wont start...
What shud i do?..... do i have to reflash it?... please send me a step by step procedure on how to reflash it... I already have here XS++ i just dnt know how to use it.. please help me.... THANKS!
Posted: 2010-04-02 14:58:10
