Sony Ericsson / Sony : GPRS, WAP, MMS and Email setup : GMail IMAP4 Outgoing EMail Problem
< Esato Forum Index > Sony Ericsson / Sony > GPRS, WAP, MMS and Email setup > GMail IMAP4 Outgoing EMail Problem Bookmark topic
Page <  123
isashach Posts: 12
I have a V800 and I followed all the advice here, but when I click send&recieve, it says "Finding Server" for a few seconds, then "TSL/SSL Hanshake Failure". How can I fix this (apart from downloading the gmail app that does NOT work on the V800)?
Posted: 2008-06-11 23:26:30
dennevhyn_31 Posts: > 500
Just configure Gmail using POP3 and not IMAP. Visit my blog and follow the steps. The link is http://sek800iemailsetup.blogspot.com. It will also give you the steps on how to configure Yahoo! Mail using IMAP.
Posted: 2008-09-05 12:36:23
StevenC Posts: > 500
@ All those who cannot receive/send emails via Mobile Email Client
Although you might have the correct setting for your mailbox, you may not connect to the server if your mobile carrier does not support Port Forwarding or something like that.
Unfortunately I cannot use the email client too snif snif :'(
[ This Message was edited by: StevenC on 2008-09-14 12:52 ]
Posted: 2008-09-14 13:50:45
Page <  123
