Windows Mobile
> Sony Ericsson XPERIA X1 discussion
On 2008-11-02 15:31:40, Tigershark42 wrote:
Here are some questions for X1 owners: when playing music with the X1, can you go to another panel or any other part of the phone and continue listening?
No not with the including media player.
The music stops immediately when you press the panel button and only continues until you select the media panel.
@d-southwest.
You will not be able to do anything with the cab file until you get your Xperia. Once you get it, transfer it to your phone and find your cab file through your file explorer (I don't know what it calls in English) found by pressing Windows logo > programme > file explorer
[ This Message was edited by: McKinley on 2008-11-02 18:20 ]
Posted: 2008-11-02 19:08:44
thanks mizzle!
wow its amazing how sharp x1's screen is!
Posted: 2008-11-02 19:22:29
@ the_mont
I've managed to get my bluetooth working now. I've no idea why it wouldn't work before but it's working now. Many thanks.
Posted: 2008-11-02 20:11:22
@d-southwest.
Thanks McKinley for your help
Posted: 2008-11-02 20:25:37
On 2008-11-02 16:50:14, Mizzle wrote:
Hopefully some of you have been using WM devices for a long time, so here's a quick question. On X1, you can use your finger to scroll through menus and lists in the WM interface. For how long has that been possible with WM?
i believe HTC introduced the kinetic scrolling in their first Touch series little after the iphone
Posted: 2008-11-02 20:36:19
So, it's not WM 6.1 standard?
Posted: 2008-11-02 20:37:32
umm not sure if they implemented it as part of the OS after HTC introduced it
Posted: 2008-11-02 20:45:42
I`m afraid that only HTC made it for now in their touch flo ... In next WM 7 this will be avaliable ...
Posted: 2008-11-02 21:07:40
To all
How is the sound quality with music playing through speakers?
Posted: 2008-11-02 21:37:40
You can use your finger to swipe through all menus on the X1.
Posted: 2008-11-02 22:04:03
