Sony Ericsson / Sony : Technical : Bluetooth specifications and more :)
< Esato Forum Index > Sony Ericsson / Sony > Technical > Bluetooth specifications and more :) Bookmark topic
Page <  123 ... 1415, 161718>
max_wedge Posts: > 500
On 2005-06-29 12:49:59, bongzino wrote:
Are there any health hazard from being exposed to to much bluetooth?
Nah mate...think about it - it's a fraction the power of your phone and a fraction of the range. Yet you stick a phone right up against your ear for the whole time it's being used?
It's high power radio waves that you want to watch, I wouldn't be too worried about bluetooth.
Posted: 2006-01-06 16:27:59
BFassassin Posts: 89
is there a way to not get asked for a passkey when connecting to new devices i know some nokias can do it
Posted: 2006-02-10 20:08:32
Ngololo Posts: 5
Hello everybody,
In fact, and specially in relation with the phone (the t68i has the version R8a 015 which is the latest software version). You will have to remember that this phone has been made on the market in the begining with the headset profile from the R1 version to the R5. And then the first handsfree profile has been made on the phone). What is the difference? The fact, is that the bluetooth headset will be linked to an other device when you will use it and will disconnect after a while (five minutes) when you do not use both. The handsfree profile will staying paired and linked with the device all the time (with a device handsfree kit, the headset profile doesn't allow to have informations of the network, level of battery and so on displayed to the other device. The handsfree profile will allow it.
I skall opmaerksom paa forskelliger produkter isaer i begynelser om det bluetooth teknology fordi det var ikke saa mange bluetooth téléfoner for tre aar siden.
Bluetooth killer
The range r520, t39M and some other has been build in the begining of the bluetooth, therefore some of the applications could not be stables.
Posted: 2006-03-13 16:05:54
k300scout Posts: 3
I'm new here and I'm not sure if I'm posting this in the right place, but please bare.
I have a k300i and a IRDA device... I can't get the two things to recognize each other. This should be very simple but it's taking several hours of my time to figure how the f*** to download my pics!!!
HELP!!!!!!!!
I have downloaded the dirver and the IRDA is a Kingsun KS-959
Posted: 2006-05-02 05:28:48
speedyandre Posts: 42
HELP!!!!!!!!
Did you activate Wireless link in XP controlpanel?
It helps XP starting to look for IR devices.
A little google search showed me that this KS-959 is known for the troubles to get it working.
I've got a Kingsun SF-620 IR dongle and it works like a charm.
André
Posted: 2006-05-06 23:55:42
kahmeelo Posts: 247
dont no if this was already post, but were can i find a bluetooth printer.
Guys wat do u think about bluetooth headfones uhh... just think about. It would be better because sometimes if your walking fast or running or at the gym the headfones plug is pluged out of the phone but, if you have the bluetooth headfones you dont have to worry about headfones pluging out only signal lost. I think it would be great if SE launch something like that
Posted: 2006-05-26 06:38:02
EastCoastStar Posts: > 500
@kah, check these links
http://www.mpitech.com/bpa/index.htm
http://blueshop.com/content/accessories/9-114.htm
http://www.amazon.com/gp/prod[....]2606-3128918?v=glance&n=172282
just a few ideas. if u need more, ill find some.
Posted: 2006-05-26 06:51:09
kahmeelo Posts: 247
thank you VM
Posted: 2006-05-27 07:53:24
P9DYL Posts: 47
I have a bluetooth printer problem.... its a samsung 2040 printer with samsung bluetooth dongle v1.2. My bros k750i and mums w900i work fine with it but when my w850i dads k800i and g/f's z610i try to send photos the dongle flashes a few times then the phone times out and says connection failed, i can find the printer fine when searching for devices, please help as ive been trying to find a solution for ages...
Posted: 2007-01-12 20:19:48
rdnymllnsktr Posts: > 500
Question here, what range does Bluetooth v2.0 have? I have a w810i, and would like to know the range of it's bluetooth.
Posted: 2007-05-03 00:25:08
