Sony Ericsson / Sony : Symbian phones : Fring on wifi on P1
< Esato Forum Index > Sony Ericsson / Sony > Symbian phones > Fring on wifi on P1 Bookmark topic
xan K Posts: > 500
I think it prefers WiFi over gprs when WiFi is enabled. dunno why, but fring sometimes hangs when I use it on WLAN.
Posted: 2008-06-19 04:03:29
myth® Posts: > 500
Put your wifi and gprs accounts in separate groups and tick the box for 'Show connection dialog'.
Posted: 2008-06-19 09:12:39
whatsucka Posts: > 500
well under my situation fring wont connect under gprs, juz da same as google maps...
both works perfectly under WIFI but wont connect at all under GPRS
Posted: 2008-06-19 09:18:42
myth® Posts: > 500
@whatsucka
You should check if you are able to use gprs at all.
If not, check the settings (apn, username & pw (if any), etc.) and make sure that you have added it in your internet group account.
Posted: 2008-06-19 09:36:07
eske Posts: 26
@myth "You the Man" !! that did the tirck.
many thanks
Posted: 2008-06-19 11:22:18
ya i checked...my GPRS is added it in my internet group account. n im sure im able to use GPRS cuz im using it rite now...(on da bus...lol)
Posted: 2008-06-19 14:47:56
sanisamudra Posts: 2
help me...! i need fring for my P1i , please give me link to download..!
Posted: 2012-03-07 11:06:54
pt020 Posts: > 500
m.fring.com
Posted: 2012-03-15 16:39:00
