Sony Ericsson / Sony : Technical : K850i. I want to replace the LCD screen.any tips?
< Esato Forum Index > Sony Ericsson / Sony > Technical > K850i. I want to replace the LCD screen.any tips? Bookmark topic
rdnymllnsktr Posts: > 500
On 2008-06-29 08:41:34, faten wrote:
Thanks guys on all the input, but I was so lucky to have found a new cell phone repair shop open a few light away from my home. The guys there are so cool and it looks like they know what they are doing but he did say that the tutorial I posted is not as easy as it looks. the phone has all these little buttons on the side for the volume and what-not & even a bit nerve racking for the experienced to replace, but totally do able cause my phone is doing good.
But still I would love to learn how to fix minor cell phone repairs.
Actually, it IS as easy as the guide says. Some of the stuff doesn't pop apart immediately, and you have to apply some pressure, but the guide is pretty straightforward. I had to replace my keypad, because since the buttons are rubber, one of them popped off since I kept putting it in my backpack.
Posted: 2008-09-12 00:11:35
betherek Posts: 3
Can anyone tell me if i can replace the K850 display from other sony ericssons of the same platform?
Posted: 2011-08-25 11:42:22
ceshiwuhao Posts: 3
i strongly recommend you to bring it to a repair shop or like that..
[ This Message was edited by: ceshiwuhao on 2013-03-08 12:02 ]
Posted: 2013-03-08 13:02:15
