Sony Ericsson / Sony : Accessories : SE HBH-IS800 Announced
< Esato Forum Index > Sony Ericsson / Sony > Accessories > SE HBH-IS800 Announced Bookmark topic
Page <  123 ... 89, 101112>
darwinian Posts: 35
On 2009-01-24 07:10:54, kjao wrote:
yesterday i got about 2.5-3hours of music playback before it gave a melodic chirp and died. i'm a wee bit disapppointed at it's battery lifespan. the right earbud got hot enough for me to remove it. and i noticed that when i grab the right earbud with a little squeeze, my music drops. i'm not sure if this is a faulty unit and i should be sending this in. is anyone else facing this?
How hot is it? The manual indicates that the unit can get warm because of the battery. However, no heat issue nor sound drop for me. You should send it out for a check or get a replacement. I will update on usage time. I honest don't think it will give more than 3.5 hours of continuous use due to its size.
[ This Message was edited by: darwinian on 2009-01-24 11:50 ]
Posted: 2009-01-24 12:43:54
kjao Posts: 200
it was hot enough for me to feel uncomfortable and have to remove it. thinking of sending it in...but erm...where's the warranty card??
Posted: 2009-01-24 13:44:57
darwinian Posts: 35
Don't you have a receipt or any proof of purchase? The unit is so new and just came out less than a month. This should do it.
What's your thought on sound quality? Does it give you a good deep bass and high treble responses?
Posted: 2009-01-24 15:36:29
buntoo Posts: > 500
i recently bought SE HBH-DS980 and the audio quality is just superb for me.
What about this one HBH-IS980 if compared to the DS980?
Posted: 2009-01-24 17:02:15
kjao Posts: 200
quality is ok but i notice i can't control the volume while using it with my W350. are they not compatible?
Posted: 2009-01-29 03:04:16
tesssst Posts: 98
can u guys summarize on the continues music play time?
Some people are getting anywhere from 1.5 hours to 3.5 - Anybody got 4 hours of play? Did you charge the unit 10 hours the first time?
Posted: 2009-03-28 12:51:47
piflechien Posts: 138
Never had 4hours of playback.
Usually 2h45 of playing time.
There is no need to charge the battery 10 hours the first time. It won't let you anyway, it stops chargin when the light turn from red to green and that takes 2~3h
[ This Message was edited by: piflechien on 2009-03-28 19:22 ]
Posted: 2009-03-28 20:20:23
karlosperu Posts: > 500
Sony Ericsson Bluetooth Headset HBH-IS800
review
http://www.finestfones.com/20[....]-stereo-bluetooth-headset.html
Posted: 2009-03-29 16:50:19
alexlt Posts: > 500
Actually you need let it charge for 6-8 hours the first times, in order the battery reaches its full capacity, after that you only need 2-3 hours as you say
Posted: 2009-03-29 17:23:36
tesssst Posts: 98
that's what I heard also, you need to charge it properly otherwise you dont get the full capacity. And some poeple are stating 4.5 hours of play time.
Anyways, what does full volume mean anyways.
With an earbud, I can get a maximum of 1/2 if not 1/3 of the maximum volume on my p1i even without the mod. Anything else is insane...
[ This Message was edited by: tesssst on 2009-03-29 22:36 ]
Posted: 2009-03-29 23:35:02
