Sony Ericsson / Sony : GPRS, WAP, MMS and Email setup : My Friends Configuration on Sony Ericsson Phones
dennevhyn_31 Posts: > 500
@med: co0l.me to0 i'm using the same trick.by the way,what web br0wser do y0u?i'm using opera mini m0d 2.06,h0w about y0u?
Posted: 2008-09-17 11:40:00
i use the default broser in my phone....
Posted: 2008-09-17 16:03:53
@med: oh ok! try it using opera mini mod 2.06. you can use the same trick there in the network settings.
Posted: 2008-09-17 17:27:51
i cant download opera mod.......i have an old mobile phone...SE T630
he you can help me..?? i have a file.. and i want to upload it from pc and dowload the file to my mobile phone.....any idea??
Posted: 2008-09-17 18:08:31
save the jar file on the OTHER folder under file manager then install it or you can send it to your phone via bluetooth. it's going to install it automatically.
Posted: 2008-09-17 23:08:26
Thank you...
I will use the first one....
Posted: 2008-09-18 12:29:00
@med: you're very welcome! thanks too!
Posted: 2008-09-18 23:47:30
hello i tried this one.. it's working on my N73 but when i tried it to my friends SE phone it doesn't work I used the same setting with 3g.myglobe....
Posted: 2008-09-19 21:20:58
There might be a problem with the internet profile On your se phone.by the way what's the unit?check first the settings.
Posted: 2008-09-20 03:43:00
@liannlar, wich sevice are you using? Mobjab, or yamigo?
Posted: 2008-09-20 15:45:00
