Sony Ericsson / Sony : Tips and tricks : Free Mobile Browsing how do i trick it
< Esato Forum Index > Sony Ericsson / Sony > Tips and tricks > Free Mobile Browsing how do i trick it Bookmark topic
Page <  123, 456 ... 474849>
med Posts: 277
On 2008-10-06 10:01:58, yea g wrote:
well Im afarid it doesn't work
so far all it says at the bottom is processing when I try to connect to wap.esato.com
true tto enter in opera mini server this link: live.vodafone.com:@80.232.117.10:80
Posted: 2008-10-06 11:36:38
fdigital Posts: 133
Guyz that opera mod method arnt working i ve tried it somany times with other proxies but it dnt go through. plz guyz is there any other trick or mobile browser that does work
Posted: 2008-10-06 12:35:00
dennevhyn_31 Posts: > 500
Maybe it is not really working in yours but it works in other countries. You know it really depends on your network provider. Actually, the settings that we're giving you are correct. I think the only problem is the address that you should put on the address to connect and with the network prefix on the opera mini server.
Posted: 2008-10-07 12:12:00
fdigital Posts: 133
please does any one knows any mobile browser like opera mod that u can configure the netwok.
Posted: 2008-10-11 00:21:00
I think there's none. Even if you will try any web browser, it will still not work because you're still gonna use the same settings. It really depends on your network provider.
Posted: 2008-10-12 01:02:00
fdigital Posts: 133
ok guys mine finaly got working with this IP:10.199.212.8@opm server. But i have problem downloading with it 'ie its in built downloader 'when ever i made an attempt to doxld it writes java server error blabla . pls i need your help cos most guys do use it to downld without charges. thanks
Posted: 2008-10-17 16:15:00
@fdigital: great job! if you're going to download using the built-in downloader, just put 10.199.212.8@ on the download link. for example: http://10.199.212.8@www.getjar.com/downloads/file.jar. that is what i'm doing and it works great dude!
Posted: 2008-10-17 17:20:53
fdigital Posts: 133
I ve tried it worked but stoped after the second download. since then it each time i made attempt to download it wil write >> server error.....check gprs/edge settings'
[ This Message was edited by: fdigital on 2008-10-21 18:46 ]
Posted: 2008-10-21 13:41:00
But where you able to download successfully on the first try? Try to clear the cache and the traffic/memory then retry downloading. If it will not work anymore, you might need to try a different IP address.
Posted: 2008-10-23 08:14:00
fdigital Posts: 133
ok i ve tried changing the cheats it worked but not all jar files that it do download, like files more than 1mb .
Posted: 2008-10-23 09:28:00
