Tips and tricks
> Tip for cleaning the fastport connector
I got that problem lately. what i did is i use lighter fluid with a small brush and dont forget to remove the battery before doing it.
Posted: 2009-02-04 07:29:27
@denn, we do have WD-40 here in the Philippines,
I bought mine at SM Supermarket for almost
P200.00
Posted: 2009-02-25 12:19:58
dennevhyn_31 Posts: > 500
@jnodcam: Oh ok. I'll try to look for one in SM Megamall. Hehehe I'm having some problems with my phone's fastport right now. The dirt is really causing problems on charging and connecting to the computer.
Posted: 2009-03-10 21:53:14
@denn
w40 is use to loosen rusty objecj like bolt and nut it for industrial use not for electronics and it has oily component
Posted: 2009-03-11 07:06:24
They said it can be used to clean the fastport of SE phones.
Posted: 2009-03-11 21:48:19
On 2009-03-11 07:06:24, aquared29 wrote:
@denn
It's true that WD-40 contains a lubricant component, and of course, it gets greasy if used in excess. Also, there are other types of products that are more dedicated for pure contact cleaning, WD-40 is more like an allround spray. However, the good thing with WD-40, or CRC 5-56, or any other similar product, is that they are not electrically conductive, but has a cleaning and grease resolving effect, and the oily component will reject water and moist from ruining the connection, thus making the electrical contact between the socket and the plug better.
[ This Message was edited by: altemyr on 2009-03-12 07:47 ]
Posted: 2009-03-12 08:46:15
@altemyr: Oh ok. Very well said. Thank you for the information. :)
Posted: 2009-03-13 00:12:00
rdnymllnsktr Posts: > 500
On 2008-11-20 08:22:25, dennevhyn_31 wrote:
I tried using a toothbrush and it removed the colored-green dirt. But after a few days, thd colored-green dirty thingy went back and then it started creating rust which causes problems when charging and using the headset to listen music. Sometimes only one earpiece works.
If you had green colored dirt, that means you got the phone wet. It's not the issue of the toothbrush you used.
Posted: 2009-03-13 22:31:04
thanks guys for the tips.
my phone cant detect the handsfree.
thought it was broken aldy.
i just clean the fastport using toothbrush.
and the handsfree works flawlessly.
Posted: 2009-05-10 07:04:40
your lucky enough and it works
Posted: 2009-05-11 18:24:47
