Network operators : Africa : Settings for free browsing in SA
< Esato Forum Index > Network operators > Africa > Settings for free browsing in SA Bookmark topic
Page <  123456789>
med Posts: 277
Ok,.. We waiting..:-) You have a sony ericsson phone?
Posted: 2008-11-11 15:39:53
sitnet Posts: 325
On 2008-11-11 15:39:53, med wrote:
Ok,..
We waiting..:-)
Yes I have a SE W800i. I tried those settings and they don't work, any other idees. Oh and by the way, do you know anything about Opera Mini on a pc because I know how to do it but I have some problems downloading.
[ This Message was edited by: sitnet on 2008-11-12 14:00 ]
Posted: 2008-11-12 14:57:37
kinibigdeal Posts: 8
hey? frnd though am 4rm Nigeria but mak sure ur shadw connect is tick dn d operaserver shld be live.vodafone.com@80.23. complete d server
Posted: 2008-11-12 20:25:00
sitnet Posts: 325
Thanx but 80.23. what, you did not complete the adress.
Posted: 2008-11-13 09:22:11
med Posts: 277
@sitnet,
Ok, but here in Morocco, we can browse with the same steps of opera mod's configurations...only the operator settings are differents..
For opera of pc, do you mean opera mini or opera windows 9.5?
I think @kinnibig, means this server:
live.vodafone.com@80.232.117.10:80
Right, @kinni.. ?
Posted: 2008-11-13 17:05:00
sitnet Posts: 325
On 2008-11-13 17:05:00, med wrote:
@sitnet,
Hey, I mean Opera mini on a pc using a java emulator (java wirless toolkit to be more specific). When using opera mini as your browser you browse much faster because of the extreme data compression. I am having a problem downloading because I don't know where to find a sighned version of opera mini because the stupid emulator keeps asking me if I want to allow opera mini to download, like every 2 seconds!
Posted: 2008-11-14 07:22:04
med Posts: 277
@sitnet,
Ah, you talked about opera mini, using it with the java umiliator,..
I'll search for a signed version for you, if i find it, i'll post it here..
But tell me, why don't you using opera windows 9.5?
Posted: 2008-11-14 20:06:00
sitnet Posts: 325
On 2008-11-14 20:06:00, med wrote:
@sitnet,
HEY, thanx but don't worry about the sighned version, I fixed the problem (http://www.esato.com/board/viewtopic.php?topic=177634). I use Opera mini because the data compression is much moer than opera 9.5 and Internet explorer so I use less data (CAP) and the pages load faster. The other advantage is that you don't get virusses so easily because websites and hackers can only access the root folder you selected.
THANX that you would have looked for the sighned opera mini and thnx for the reply!!! :)
Posted: 2008-11-15 10:10:09
med Posts: 277
@sitnet,
You're very welcome..
I will see the topic, thank you.
Posted: 2008-11-16 10:09:00
white cloud Posts: 11
Im unable to get the settings correct for free browsing on my motorola v360. Is there someone that can help me fix this.I already have downloaded opera mini mod 206 and opera mini 4.2. The opera mod wont open webpages at all and just says processing for a few seconds and stops.Opera mini 4.2 works fine but still takes airtime even if i change proxies. I have found alot of proxies that i still did not try but need help with the correct gprs and opera mini settings especially with opera mini 4.2. And im using mtn. Help will be much appreciated.
Posted: 2009-01-13 16:08:00
Page <  123456789>
