Sony Ericsson / Sony : Software, Firmware and Drivers : N1 C702 & C510 camdrivers
@yesno
You can try my camdriver, find it in other topic started by me.
Posted: 2009-04-13 16:50:00
whats the difference between the original and yours
Posted: 2009-04-14 18:21:57
Just upload it to your phone, and test by yourself. Maybe there's need an improvement, that's why i need some feedbacks
Posted: 2009-04-14 18:51:54
newbie here, some 1 help ?
I try to use N1 3.3 beta camdriver on my C510, it's works!!
but, can or not turn on LED light to shot?!
how to turn on/off ?
my C510 Firmware
R1DA029
here is my original camdriver0 as below...
http://rapidshare.com/files/221693279/camdriver0.dat.html
BTW, 3.25 camdriver can not work on my c510
[ This Message was edited by: phyche on 2009-04-15 17:38 ]
Posted: 2009-04-15 18:32:36
the problem is that those camdrivers arent for your phone. they are for c702.
Posted: 2009-04-15 19:30:47
No problem - copy this part from c510 driver and replace the same part in c702 driver (at the top, about +-10th line, you will see (or you can just change a few numbers...but I was lazy, so I used ctrl+c
Code:
//Camera characteristics section
// Kate 3M camera Power on sequence
cam_power_on_0 = 5, 0, 00, 1, 05; // Active Main Camera RST pin, delay 5ms
cam_power_on_1 = 5, 2, 91, 1, 05; // Videocamera standby (AppGPIO_09 = GPIO_91)
cam_power_on_2 = 5, 2, 96, 1, 02; // Vcam_SA (AppGPIO_14=GPIO_96) delay 2ms
cam_power_on_3 = 5, 2, 85, 1, 00; // Vcam_Core_AF (AppGPIO_05=GPIO_85)
cam_power_on_4 = 5, 2, 95, 1, 05; // Vcam_IO (AppGPIO_13=GPIO_95) delay 5ms
cam_power_on_5 = 5, 3, 09, 32C8, 05; // Turn on 13 MHz clock, delay 5ms
cam_power_on_6 = 5, 0, 00, 0, 32; // Disable RST , delay 50ms
// Kate 3M camera Power off sequence
cam_power_off_0 = 5, 0, 00, 1, 10; // Active Main Camera RST pin, delay 16ms
cam_power_off_1 = 5, 3, 09, 0, 05; // Turn off 13 MHz clock and wait 5 ms
cam_power_off_2 = 5, 2, 85, 0, 00; // Vcam_Core_AF (AppGPIO_05=GPIO_85)
cam_power_off_3 = 5, 2, 95, 0, 05; // Vcam_IO (AppGPIO_13=GPIO_95) delay 5ms
cam_power_off_4 = 5, 2, 96, 0, 05; // Vcam_SA (AppGPIO_14=GPIO_96) delay 5ms
cam_power_off_5 = 5, 2, 91, 0, 05; // Release Videocamera standby (AppGPIO_09 = GPIO_91)
Problem with LEDs would be bad, when nobody here can test it on c510.
Posted: 2009-04-15 20:29:28
@phyche
You would use my mod camdriver, it's been here at another topic. It seems work on C510. Maybe my mod camdriver not as good as #1's mod camdriver because it has still need an improvement, thats why i need some feedbacks from C510's user like you
@Mr. Kŕja
Not only these sections are different, there's much more. Such like trig section, sup_properties, zoom, focus operation, led, etc.
Posted: 2009-04-16 03:22:53
@code28h4p
okay, I got your mod driver, I'll try it
@tranced
oops., I think this is use to in C510 & c702 (Such as the title indicates) :-/
BTW, N1 3.3beta camdriver in C510 got some problem as below...
1)sometimes can not save shot(image) (donno why)
2)LEDs Light not work (can not auto run(on) in the dark(low light)
Posted: 2009-04-16 07:04:48
code28h4p: This is only change between c510 a c702 driver from N1, so why it should not work for c510 in N1 3.25, when it worked in N1 3.3 case?
[ This Message was edited by: Mr.Kája on 2009-04-16 10:35 ]
Posted: 2009-04-16 11:25:26
I've said there's so many, if you just copying camera characteristic only, in my opinion there's will have much bugs in camdriver.
Did you see phyche's post, his camera have some bugs after use #1's.
[ This Message was edited by: code28h4p on 2009-04-16 11:51 ]
Posted: 2009-04-16 12:48:28
