Sony Ericsson / Sony : Software, Firmware and Drivers : N1 C702 & C510 camdrivers
@psyche: I have no time, so I i quickly did mix of original c510 and N1 c510 drivers mix...it won't solve your problem(s) on 95%, but I'm just curious, what would it do with c510..can you try it? I would like to know, what does it do with leds.
www.camdrivers.wz.cz/camdriver0.dat
@code: Sure, differences are there, I just wanted to help him in reactin on 3.25 not working...he can turn it on with this. Anyway, stock c510 and c702 drivers are not so different...it's almost similar..only a few lines and on/off + led/xenon sections are quite different...I quess, these problems are not huge problem, but nobody with c510 tried to use notepad and custom it.
Posted: 2009-04-16 16:54:59
@Mr.Kája
I try to use that camdriver, its not works!!!!!
can not in camera mode, auto log out(back) to main menu.
BTW, my ID is phyche :-Q
Posted: 2009-04-16 17:14:33
Oh, I knew, it won't
Pity...maybe I will take a look on it later. Sorry for the nick, last time, I'm little confused:)
Posted: 2009-04-16 17:47:43
Did you see Mr. Kŕja? I've told you before. But i've appreciated your efforts. I believe you can mix it soon.
If you want it, don't do change wait_for_trig line, imo.
Sorry...i'm just a beginner here.
Posted: 2009-04-16 18:47:24
3.3 was just a beta, it was never tested.
Posted: 2009-04-16 20:49:42
@code28h4p: I'm beginner too...and what else looser (usually things, which I do, make disasters:)). But anyway, I don't have much time, thx school and sunny weather, but maybe in July (maybe earlier). But I'm sure, all these problems will be solved, if your and other moders work will be going as well as now.
In my mind, I think, the problem can be solved, if you "patch" original c510 driver and dont touch led and xenon and etc. sections...i tried in quickly and in a bad way...seems, I can't do miracles, how I expected:))
Posted: 2009-04-16 21:14:22
I've already fixed the problem, i am working with code28h4p now so i've emailed him the drivers, i also fixed the framerates problem some1 made a video of a few pages back, i've tried to fix the led misfiring bug aswell by reducing the exposure time to 1/2 iso320 (MAX exposure time) when twilight landscape uses the led, has whitebalnce colour correction and few other small tweaks.
Posted: 2009-04-16 22:00:53
number1
See ! Pictures
Test ------- > Your Camdriver with code28h4p
http://wsxproxy.persiangig.com/W_S_X/C702-Cam-TEST-1.jpg
http://wsxproxy.persiangig.com/W_S_X/C702-Cam-TEST-2.jpg
http://wsxproxy.persiangig.com/W_S_X/C702-Cam-TEST-3.jpg
http://wsxproxy.persiangig.com/W_S_X/C702-Cam-TEST-4.jpg
http://wsxproxy.persiangig.com/W_S_X/C702-Cam-TEST-5.jpg
http://wsxproxy.persiangig.com/W_S_X/C702-Cam-TEST-6.jpg
Posted: 2009-04-17 01:11:37
hey all the smart people over here
hey guys something happened to my C510
ive just used it for a week
and now its showing no network coverage no battery colour like green red
even though its charged and shows 82 %
also i cant tranfer files from bletooth
CAN ANYONE HELP ME OVER HERE
Posted: 2009-04-23 06:43:21
ok now my cell is working 100% normal thanks to SEUS update
i noticed that older formware R1DA029 had lots of bugs
But now mine is R1DA032
lets see if this firmware has bugs
Posted: 2009-04-23 08:47:52
