Manufacturer Discussion : Nokia : Nokia N97
< Esato Forum Index > Manufacturer Discussion > Nokia > Nokia N97 Bookmark topic
Page <  123 ... 2829, 303132>
Pitzon Posts: 435
What do you mean by "lack of virtual keyboard" ? It has just the same keyboard as the 5800 xpress if you want to. As soon as you click on a field where you can input text it pops up.
I was also a little bit annoyed at first because the auto rotation of the screen was off by default. (inside phone settings) Now i can tilt the phone and use it without the keyboard if i want. There are many ways of input text.
I updated the phone to v.11 without any problems. Nothing seems to be erased during the process and my contacts, cam pics and so on was still there.
I had some trouble with Map Loader and had to set the phone to mass storage to make it work. I figured that out after some cursing
The cam seems actually quite good for being in a smartphone. It runs fast and everything feels amazing so far.
Posted: 2009-07-12 01:18:33
alexho Posts: 453
On 2009-07-11 19:32:40, aasimtom wrote:
On 2009-07-11 15:30:34, RayHon wrote:
On 2009-07-10 13:32:44, aasimtom wrote:
Guys how to find File Manger in N97, I inserted my msd card but how to access it? Anyone
Go to office and there's is a file manger in the office folder which is located in the applications menu.
Thanks, its there. I was using the method posted by Gucci; the search one.
Did anyone try to debrand their N97? What do you guys think about this method I found on google?
[ This Message was edited by: aasimtom on 2009-07-11 18:35 ]
i used this method and change the firmware to hk version without any problem. This is by far the easiest way to debrand your phone and u can change the firmware back easily!
Posted: 2009-07-12 02:45:39
Pitzon Posts: 435
Some shots from me, the cam produces quite oversaturated colours and often some yellowish tint but they are sharp so this is no big problem for me to tune them in pc later on.
I think itīs quite comparable with n82 in good light as someone said earlier, the same hard compression of pics are here. The pic size varies but seldom above 1mb. This compared to my c901 who are much better and have less compression.
Good cam for being in a smartphone though, it seems to work quite good indoors in bad light too.
I also tried the GPS and the FM-transmitter today and it worked fantastic, havenīt found any bug yet.
Posted: 2009-07-12 20:00:05
aasimtom Posts: 165
I did change the fw version using this method but after nokia update, I found my phone bricked...
To be more specific, I am talking about full keyboard not alphanumeric.
Posted: 2009-07-14 18:08:18
intelegent115 Posts: 470
I second the that. Virtual keyboard (full querty) shoud be there.. And I do not mean via third party appz but built-in by nokia. You should be able to switch between alphanumerical, full querty and handwriting..
Other than that, i find the phone quite good.
@Pitzon: nice pics..
[ This Message was edited by: intelegent115 on 2009-07-14 18:05 ]
Posted: 2009-07-14 19:04:27
aasimtom Posts: 165
^^^ Yeah I have no complains either but the kb is not there, only Alphanumeric and Handwriting; that's it.
BTW, does anybody know what's the code for master reset? It doesn't work on 0000.
Posted: 2009-07-14 20:17:54
lemmy31 Posts: > 500
Nokias default code is 12345 to master reset
Regards Craig
Posted: 2009-07-14 22:34:15
aasimtom Posts: 165
^^^ Thanks craig
One more thing. I am a newbie to Nokias and if I master reset, will it wipe out all the data on 32GB memory? I know it will to phone's (separate) memory. The phone actually shows both the memories separate though. So I guess the master reset would only format phones memory not the 32GB one. Right
Posted: 2009-07-15 00:14:29
Bonovox Posts: > 500
Whats the speed and screen touch like on this phone? Reason i ask is What Mobile mag did not rate this phone highly at all. They said its slow and screen is not very repsonsive.
Posted: 2009-07-15 01:09:00
KaMeL Posts: 7
Nice phone but needs more than 5 mpx camera
This message was posted from a N95_8GB
Posted: 2009-07-15 01:20:36
