Regional : Americas : GPS y Cartografia para Moviles en General
< Esato Forum Index > Regional > Americas > GPS y Cartografia para Moviles en General Bookmark topic
Page <  123 ... 131415, 161718>
cammerv8 Posts: 73
klk gente yo tengo como poner el mapa mas actual ( puede ser de ola) en el garmin xt en el n85 y cual es el mas actual ( link plz)
Posted: 2009-09-29 05:15:35
fbloise Posts: > 500
GPS with Offline Maps - Blackberry
On your Bold (can be done on Curve 8900 or Tour):
1) Go to - Options - Advanced Options - Location Aiding - Turn this to DISABLED
2) Put in your MicroSD card
3) Connect your BOLD to your computer via USB cable
4) When the window comes up asking you whether to enable Mass Storage, say YES
On your computer
1) Make sure you can see your SD card (it will be listed as a removable disk drive)
2) Go over to Map Creation Tool for MGMaps and follow the instructions to outline your custom map, I would recommend going from 0-16 (zoom levels), and SLOW and DETAILED level of detail
3) Save your custom map on a dekstop or somewhere where you can see it, but becareful to save it as "mymap.map" with the quotation marks, and select All Files from the Save File As drop-box.
4) Next click the link to download and install GMAP Maker www.mgmaps.com/cache/gMapMaker-setup.exe
5) After installation, open GMapmaker, and press GO -> it will ask you for that mymap.map file you saved in Step 3
6) Wait for the download to finish (this will take a long time)
7) When everything is said and done, copy the MGMapsCache folder (located probably at C:/ProgramFiles/GMapMaker/) to your SD card
Install the signed version of MGMaps Index of /projects/mgmaps/Blackberry using Windows Desktop Manager
Back on the BOLD
- Open up MGMaps, go to Settings - Maps - Stored Maps - and select Offline Mode and Stored Maps
There you go, now you can track your position for free, anywhere, free of charge. Enjoy my friends
Posted: 2009-09-29 16:19:37
[ This Message was edited by: fbloise on 2009-10-26 02:04 ]
Posted: 2009-09-29 17:31:54
cammerv8 Posts: 73
eso funciona con el n85? y con el garmin?
Posted: 2009-09-29 18:26:59
No, nada de eso funciona con Garmin. Ese ultimo tuto es para usar mapas offline en las blackberry usando algo parecido al trekbuddy llamado MGMaps.
Para el Garmin es con otro tuto y se usan los mapas de Ola o de OSM (en formato IMG). Lee este topic (al principio) pa que no estes con la preguntadera estilo tontin en el pais de los GPS.
Posted: 2009-09-29 18:29:50
cammerv8 Posts: 73
ya yo baje el de OSM solo me falta instalarlo
Posted: 2009-09-29 19:03:48
Ese es cool, aunque no tiene todas las calles delimitadas como el de Ola map.
Posted: 2009-09-29 20:13:35
krlosRD Posts: > 500
Voy a ver si está actualizado. La última es de JULIO '09 si no me equivoco.
Yo traté de aportar pero me lo encontré un poco complicado en ese momento. Quizás vuelva a intentarlo luego.
Posted: 2009-09-29 20:26:19
cammerv8 Posts: 73
yo tengo el ola de la oooooootra vez el primero que postiaste en el foro do. este osm es mas avanzado que ese me inmagino, no?
PD: foro do locked foro do unlocked
[ This Message was edited by: cammerv8 on 2009-09-29 19:30 ]
Posted: 2009-09-29 20:27:19
tu tienes el primero ola, v1.0
Ya va por el 5.5
Posted: 2009-09-29 20:44:18
