Sony Ericsson / Sony : Software, Firmware and Drivers : Tutorial: Flashing A2 phones
< Esato Forum Index > Sony Ericsson / Sony > Software, Firmware and Drivers > Tutorial: Flashing A2 phones Bookmark topic
Page <  123 ... 26, 272829>
tranced Posts: > 500
Not sure but the files you used it's for CID52 and yours is CID53.
What version of the A2uploader are you using?
Posted: 2010-05-06 03:21:01
zizolz Posts: 30
I dont know actually .. i found it in google and they've said its the last one but not cid53 compatible and now i found a2uploader cid53 supported .. I'll try it asap and see if it'll work .. but what kind of frimware should i use ?
Posted: 2010-05-06 05:30:13
v7 Posts: 30
I have a ˝problem˝ with A2 Uploader.
I'm trying to delete locked files (eg. themes, pictures, sounds) from my phone (C905, CID53) but A2 Uploader won't do it.
I select file which I wanna delete, select SET RW ACCESS and A2 reports me an error, and FS EXPLORER shuts down.
I have newest version of A2 Uploader 22.09. (at least I think it's newest).
I didn't have any problems deleting that files on my old phones, which were, if I remember correctly, also CID53.
How can I solve that?
Posted: 2010-06-13 00:16:55
devil2887 Posts: 19
where can i download the fs and main firmware sir? also the other needed custom..
Posted: 2010-07-31 07:26:54
ceaser2008 Posts: > 500
Your main is right. Its generic one, based on your Pm.
If you are from philipines, why dont you try this fs for asiapacific and nz.
http://www.4shared.com/file/R[....]R1FA035_FS_APAC-ANZ_RED52.html
And the custom-pack
http://www.4shared.com/file/l[....]_1201-0102_R11A_GENERIC_A.html
This will have your philipino language as well.
Try this.
Posted: 2010-07-31 07:33:47
devil2887 Posts: 19
where can i get the cda file sir? i need 3 files right?
Posted: 2010-07-31 07:34:50
Forget that. You dont need any cda files. You only need main, fs and custom pack. Thats it.
And a2uploader to flash the phone.
Edit. I dont think custom files are called cda files. I think custom files are different and cda files are different.
I have already posted what you require to flash. Now its your turn to do the job.
[ This Message was edited by: ceaser2008 on 2010-07-31 06:40 ]
Posted: 2010-07-31 07:38:10
devil2887 Posts: 19
ow.. thanks sir.. ill try it.. .. the earlier main i've shown u sir is right?
then cust and fs is the one u've given me.. thanks sir
Posted: 2010-07-31 07:40:19
Yes your main is right.
Posted: 2010-07-31 07:41:37
devil2887 Posts: 19
sir, it says "can't get ACK"
Posted: 2010-07-31 07:58:56
