Sony Ericsson / Sony : Software, Firmware and Drivers : C510 & C702 Cyber-shot CCD
guys... code , Number1, raidersky, BrAzzUkA,strong .... there are many gods of modding camdriver here....can any body save c510 camera quality???
but no gods haven't completed the CCD version of camdriver for c510.....
try something for c510 guys pls..... R1FA035 In this i tried using codealpha driver.. after taking picture its becoming black...i didn't expect a digital camera quality, but atleast i need a 3mpx clarity ...my k750 , k790 were better than this mobile!!!!
its been so worst , its been annoying to use the camera.....
so guys if you see this message,, pls do reply .. waiting for your reply guys!!!
Posted: 2009-10-15 15:35:37
Can you give me download link for newest modified C702 camdriver?? If that isn't a problem...
Posted: 2009-10-15 20:01:20
Nari
C510 camera wasn't designed to be great and as you can see it isn't. you can't make it any better than it is now, besides it's not that bad
Posted: 2009-10-15 22:21:09
@Raiderski
thanks for the reply friend........
but will there be any
newly modded camdriver for c510?
Posted: 2009-10-16 12:44:47
@Raiderski
How to change shutter-speed to 2s in twilight?
I can't change
Posted: 2009-10-16 12:53:04
Nari
I don't know, if someone with C510 will try then yes but don't expect better quality
ds
1. find: seq_set_prop_10_3
2. some lines below find: #COM_EVENT(51,04)
3. change 04 to 01
in this way you should be able to achieve 2s in very low-light conditions
Posted: 2009-10-16 16:14:02
I have a Q
Can I take some code in another phone's camdriver in C702's camdriver?
Posted: 2009-10-17 07:06:06
in 99% this code will be incompatible with C702 driver. most compatible driver for C702 is C510
[ This Message was edited by: Raiderski on 2009-10-17 09:01 ]
Posted: 2009-10-17 10:01:09
3. change 04 to 01
But only 1/5 s
Posted: 2009-10-17 12:26:16
time depends on light conditions. with 01 should be able to use 2s but only in very dark conditions
Posted: 2009-10-17 12:44:53
