General discussions >
Esato forum
> Esato bugs
and using opera
Posted: 2009-05-22 17:58:46
Look
here
Posted: 2009-05-23 11:48:26
yes, i have that problem too, i keep seeing ALL todays posts, instead of just the new ones ?
Posted: 2009-05-23 12:04:54
Just Clear your cookies, matey, and it should be alright again. If you're using t'internet explorer it's under tools - internet options on the first tab. Make sure that the checkbox for 'cookies' is ticked before you hit the 'clear' button since it isn't by default.
Posted: 2009-05-23 13:01:29
Clearing the cookies doesn't work for me. Initially it looks like it has worked but further presses of "Mark all as read" brings back lots of messages
Posted: 2009-05-23 16:21:06
Agreed, i get about 5 days worth
Posted: 2009-05-23 17:57:10
Muhammad-Oli Posts: > 500
Yep same thing is happening for me. I am seeing 5921 new messages right now, and we all know how often I'm around! I'm also getting logged out really often. Up to every half an hour even.
Posted: 2009-05-24 14:41:03
I had this "new posts" problem when this topic started, but manually deleting the cookies solved the problem for me and its been working as normal since... and that was with both IE6 on XP at work, and IE7 on Vista on my laptop
[ This Message was edited by: masseur on 2009-05-24 13:56 ]
Posted: 2009-05-24 14:55:15
I'm still experiencing it. When I press the "mark all posts as read" button, it doesn't clear them.
Posted: 2009-05-25 04:07:51
On a post I made on another thread, esato deleted half of the message. All I did was write it then press submit, and when I checked back on the topic page, only some of the words of my post were showing.
Posted: 2009-05-26 08:28:55
