Sony Ericsson / Sony : Software, Firmware and Drivers : K850 Cybershot Xperience camdriver - New v 9.0
< Esato Forum Index > Sony Ericsson / Sony > Software, Firmware and Drivers > K850 Cybershot Xperience camdriver - New v 9.0 Bookmark topic
Page <  123 ... 19, 202122>
ceaser2008 Posts: > 500
In fast shutter speed, you need good amount of light otherwise it will always be dark. You can use that function in day light very well.
Posted: 2010-09-19 12:58:00
i_luv_se Posts: 7
Hello Everybody. I AM using K850i for 3 years and is very good phone.The only problem i got is with camera.The colors are not real.But i found that c902 and c903 are also same as k850i(DB3150) except face and smile detection.I found Chombos1_C902_camdriver_V2.5 and it got code for color correction and whitebalance like...
WB_CC =
#SET_REG(66,0A) //00-7F Yellow 80-FF Purple
#SET_REG(65,F7) //00-7F Cyan 80-FF Magenta
#COM_EVENT(13,01) //enable manual CC
and WhiteBalance Lock is given.Which calculates whitebalance before focusing.And i added some other codes in Focus operation from his driver.
WB_LOCK =
#COM_EVENT(11,03)
#COM_EVENT(11,02)
#COM_EVENT(11,02)
#COM_EVENT(11,01)
I dont know much abt codes but i can understand what it actually do.I copied Code from his driver and made changes in the original and the results are great. Witchking can You include these codes in your next version so that the colors are more accurate.
samples of red
previous red::
[ This Message was edited by: i_luv_se on 2010-11-01 14:54 ]
Posted: 2010-11-01 12:27:03
i_luv_se Posts: 7
This is the camera driver.......i modified..........Driver...
Plz watch pics in full size..there is a lot of difference between full res and compressed one.
[ This Message was edited by: i_luv_se on 2010-11-01 11:37 ]
Posted: 2010-11-01 12:36:04
NoelBonel Posts: 38
Everyone!!! New version of Witchking's driver is now available at se-nse.net. You can download it there.
Posted: 2010-11-01 13:00:57
i_luv_se Posts: 7
@NoelBonel the link is removed.can you upload it in 4shared.
Posted: 2010-11-01 19:01:15
witchking Posts: 231
@ I_luv_se
The codes for auto WB are problematic as they can often select Incandescent WB instead of the correct one, and the image gets blue and spoiled.
I shall see if the codes can be fixed and will include them in new version.
Posted: 2010-11-06 16:50:06
D1ma Posts: 54
Your manual settings is good!
But qality of pictures isn't very good...
Can you add your manual settings, and video recording in this driver http://www.4shared.com/file/DSqxSRf2/camdriver0.html ??? This driver produce much better qality then yours((
Posted: 2010-11-22 14:53:03
amnher Posts: > 500
I recently nought a new k850i from SONY. Got it for for around 115USD ill try the drivers
Posted: 2010-12-09 11:12:56
amnher Posts: > 500
Who are my pictures washed out? I used auto
Is there a problem with my k850?
Posted: 2010-12-10 01:56:16
Aodh Posts: 9
try this supercamdriver mate supercamdriver k850 the colors awesome! and the manuall settings with control functions are amazing
Posted: 2010-12-19 21:52:02
