Regional : Asia Pacific : [ New! ] BOLT 1.04 Latest Version [editable server na!]
Asia Pacific
UP!
freesite.t9space.com/power/s/http/
N0TE: sa free site na gagamitin paki rem0ve ng http:.//
ei.
http://wap.smart.sugapa.com
dpt
^^,v peace 0ut smart.. j0ke lng...
Posted: 2009-07-13 06:28:00
up natin c bolt hehe
let's bolt in......
Posted: 2009-07-13 08:14:32
dati nung bago palang itong bolt es,nadownload ko pa ung file then dinelete ko nung ndi masyadong gnagamit. then nagkarun ng bandwidth issue. nung ok na uli,nung sinubukan ko idownload ung file,snasabi na file not suported.k750i gamit ko.bkt kaya?tnx in advance
Posted: 2009-07-13 09:53:00
g0odha if id0d0wnload m0 na sabe file n0t supp0rted continue anyway? yes or no b?
try m0 id0wnload ch0ose yes at after d0wnloading nsa others ung file and click install...
Posted: 2009-07-13 09:56:00
@broad
cge.il try it.on another note,tnx sa gof1 sa tk.may gof2 ka na working?patapos na ako sa gof1.
Posted: 2009-07-13 10:03:00
98% explored nba? hehe ngf0rmat aq ng ph0ne nwla ung lar0 q,aun tnamad na q.hehe nsa lapt0p
ung g0f2 upl0ad q nlng t0m..hehe pm kta 4 d link, bwal d2 un..hekhek dun nlng ulet xa tk...
Posted: 2009-07-13 11:17:00
Bt gan0n,ayaw mgw0rk skin..haha..tnatamad ata c b0lt..t0ink!
Pg in0open q fs,walang nangya2ri..sn0oty t0ng c b0lt skin..nyahehe
Posted: 2009-07-13 13:05:07
@bheng
punta ka sa menu preferences then tanggalin mo un naka x sa https
Posted: 2009-07-13 13:11:29
bhengt0t 4g0t to say... hnd gumagana xa fs at 0ther l0g-in sites ang b0lt.hehe at 1st rem0ve the X sa http inside the preferrence pra makal0g in ka sa ibang sites,
ESATONIAN CHATBOX
SpEaK wHen yOu aRe aNgry aNd y0u wiLL mAkE tHe bEsT sPeeCh y0u wiLL evEr rEgrEt....
broadmind powerdby: ANGERmngt
[ This Message was edited by: broad.mind on 2009-07-13 12:12 ]
Posted: 2009-07-13 13:11:00
@broad
hindi pa naman. pero malapit na 90%. many thanks po. ill just check sa tk tomorrow.thanks btw. working yung bolt after downloading.bakit kc mayrun pa nung "file not supported"...dati kc ive encountered such message and when i installed, talagang wala.anyway many thanks po in advance.
Posted: 2009-07-13 15:19:00
