Sony Ericsson / Sony : Technical : 1.3.2.7 drivers for dongles / MORE audio howtos on 1st page
Technical
i am using a wavelinker usb dongle not with drivers or software that came with it but with tecom driver found on esato-
it read my bluetooth places version 1.3.5 copyright 2001 widcomm ltd licsened by tecom.
having no problems with these at present
which link should i use to up date them
thanks in advance
Posted: 2003-01-24 17:43:00
for each dongle i need vid and pid which are often included in the usbtw.inf ; but in the 1.2.2.13 and 1.2.2.16 drivers there's a good list of dongle to be accepted but none is clearly branded as a tecom one
which one is the tecom ??
USB\VID_049F&PID_0027 ; COMPAQ CSR based VID&PID
USB\VID_04BF&PID_030A ; IBM CSR based VID&PID
USB\VID_04BF&PID_0309 ; TDK CSR based VID&PID
USB\VID_04BF&PID_0310 ; IBM BDC CSR based VID&PID
USB\VID_0A12&PID_0001 ; CSR VID&PID
USB\VID_08EA&PID_ABBA ; Ericsson VID&PID
USB\VID_0B7A&PID_07D0 ; Zeevo VID&PID
Not having this answer i tried to set a multi product driver which is tecom.rar...wiating for user feedback, if it doesn't work, i'll make a driver for each of the dongle above..one should match the Tecom - the csr is my personnal favourite
Posted: 2003-01-24 18:07:00
gadgetboytom Posts: > 500
i also have the wavelinker and that crappy program that comes with it blue manager is pissing me off
how do i sort another program out?
Posted: 2003-01-24 18:12:00
can u give me a link to reach your dongle's drivers ?
Posted: 2003-01-24 18:14:00
fao gadgetboytom
all i did was uninstall the crap software that came with the wavelinker and get the new one via a link on esato its under the tech forum and it one of the first couple of threds. or
http://www.tecomproduct.com version 1.2.2.16
it has a hyper link to the tecom and downloads straight away.
after that i took out the dongle installed the software rebooted the machine and plugged in the dongle.
after that paired the phone and comp and started syncro/downloading etc no probs at all.
common
the web site for the drivers that come with the dongle is
http://www.ivmm.com
i discarded these and used the tecom ones
[ This Message was edited by: slattery69 on 2003-01-24 17:42 ]
[ This Message was edited by: slattery69 on 2003-01-24 17:43 ]
Posted: 2003-01-24 18:31:00
My case:
MSI+R520 (Win98) -> Audio gateway connection attempt -> No errors for the first 3 seconds
-> after this - "Connection closed by remote device" message...
2Everybody who's succeeded: could you try this with R520, please?
Posted: 2003-01-24 18:39:00
On 2003-01-24 18:39, vve wrote:
My case:
I'd the same issu during my tests, try to redo your pairing..the only thing i know is when it wans't ok i had a new accseory called "accesory" and when i have it working witj some luck actually the new accessory is called "HBH"
If anyone has a good howto on audio..
Posted: 2003-01-24 18:45:00
Thx to pljackson for his howto
1)pair headset with PC
2)repair headset with P800
3)pair P800 with PC
4)turn off headset
5)when a call comes in, or after you initiate a call, goto Audio gateway then select your P800... the audio should be transferred to your PC's mic and speakers.
I coudl'nt test it at this time, gshare your experience !
For the wavelinker dongle, it appears to be very very close to the windigo one...the delivered software hasn't enabled me to get tje .ibf file...if someone could mail me this file, we may have a quick test driver for these products - i had no confirmation they were CSR compliant, but the fact that they accept tecom drivers confirms thery have a 3030 chipset which -
Posted: 2003-01-24 19:22:00
Here I found another link for TDK drivers
ftp://ftp.communica.se/pub/tdk/bluetooth/tdk1.3.2.7.zip
Posted: 2003-01-25 13:41:00
Thx i update the topic
In fact i don't think only the link on tdk is down, but the whole site
[ This Message was edited by: c0mm0n on 2003-01-25 12:44 ]
