Sony Ericsson / Sony : Technical : 1.3.2.7 drivers for dongles / MORE audio howtos on 1st page
Technical
On 2003-01-30 10:08:00, emo wrote:
now here's my new problem. after installing c0mm0n's software everything worked perfectly. but, after i shutdown my computer and boot it up again, my phone can't see my pc anymore and vice-versa. i have to uninstall and reinstall the software to make it work again. HELP!!!
I have the EXACT same problem as Emo. Any fixes to this?
Posted: 2003-08-30 16:52:43
I'm tryign to set up voice gateway on my PC to use it as a GSM Headset. I have a Billionton Class 1 USB BT Dongle. The phone pairs fine, audio connection is formed, but, here is what happens : I Call a number from the cell phone, once connected and I can hear the other side, I click on the Vocie Gateway icon in my T610 Servies under My Bluetooth Places- the status changes to Connected. I get a blue headset icon on top of my T610 screen (same as the one I get when the phone connects to the BT kit in my car). But thats it, the sound coming from the phone stops, but no sound comes from the PC speakers.
Any way around it?. The Dongle came with 1.3.2.7 drivers.
Posted: 2003-09-04 01:45:40
Anyone?..ANY ideas?..HELP!!!!
Posted: 2003-09-04 14:30:56
Has anyone has any success with billionton & socket CF?
Posted: 2003-09-08 08:30:21
The Anycom FTP server host a new version of the Widcomm Driver 1.4.2.10... check in the MISC Folder... the license.dat file from previous 1.4.x versions seems NOT to work.
CW
[ This Message was edited by: ChiefWahoo on 2003-09-11 19:58 ]
Posted: 2003-09-11 20:58:06
I read all the pages of this thread but nothing suitable for me. Nobody's writing about a little violet-blue CSR Bluetooth device with no name on it
Any suggestions witch Software and firmware can I use to update it ....? Have connetctivity problems with my t610 ....only the file transfer goes smooth .....everything else do not. Even the pccontrol says it's connected but the accessories menu is grayed-out. Any help please ?
Posted: 2003-09-15 11:42:54
Hi,
I am using a BTU02 from Air2u USB (transilica) dongle between my PC and T68i and struggeling with some unstable COM. I am using the Widcomm 1.2.2.15. Any idea where I can download latest driver and software?
Thanks
Posted: 2003-09-16 08:34:42
I have also managed to get the PC to receive the calls from the phone (T610) but cannot hear any audio from the PC speakers.
ANyone any ideas.
TIA
Posted: 2003-09-25 11:25:26
Hi!!! Do anyone know wich software to use with BTM1000 and Jabra BT200 ?
I use widcom's software to sync my computer and mobile...
Have tried tdk... It dont work!!!
Links:
http://www.abocom.com.tw/product_detail.php?id=142
http://www.widcomm.com
Posted: 2003-10-14 09:07:20
Hi there,
Am trying to use my HBH-35 as a headset for the PC.
Using MSI Widcomm Drivers/Widcomm 1.3.2.7
Got everything paired up.
Headset connects.
However, after I answer the ringing on the HBH-35,
I do not hear anything in the headset.
I have checked my audio properties and it is set to Bluetooth Audio.
Any ideas?
Cheers.
Posted: 2003-10-22 01:29:25
