Sony Ericsson / Sony : Technical : 1.3.2.7 drivers for dongles / MORE audio howtos on 1st page
Technical
Anyone using bafo BT USB adapter??? Please help ...........................Thanks !
Posted: 2004-02-04 14:39:25
Never heard of, try to find its clones
edit :
I just noticed i have tons of PMs, hadn't been noticed by mail nor seen them when checking the post, sorry for people who wrote to me ;
[ This Message was edited by: c0mm0n on 2004-02-04 16:38 ]
Posted: 2004-02-04 17:34:08
Hi i have the same question as 'kewl_mobile'
i also have the tecom BT3030 installed on my sys
with the original software, any rec0mm0ndations
on what i should install to get it working like you guys do?
any1 got it working with bud 'BT3030 Tecom'?
peace!
Posted: 2004-02-04 18:51:06
newer version of widcomm
Works with my windigo dongle just fine. Have heard of people having instability problems with past versions, but no problems so far here.
http://www.sachat.net/files/Widcomm_Bluetooth_1.4.2.21.zip[ This Message was edited by: Jinxo on 2004-03-04 23:02 ]
Posted: 2004-03-05 00:00:19
Ive got a Cambridge Silicon Radio usb dongle and P800. Running XP pro on PC. Can anyone advise if I should use the supplied software or not. where can I get advice on configuring pc for sharing broadband connection?
Posted: 2004-03-10 16:03:00
thank you c0mm0n, you saved my dongle from being smashed!
whew!
Posted: 2004-04-23 23:49:53
MA-700 & T610
under xp sp2 with original drivers works fine.
ALSO used the TDK 1.3.2.7 software with modified .inf and get only the file transfer working. When trying audio there will be no sound in pc speakers.
Just wonder if this MA-700 supports audio ,if any of you do it ? and
how to do it ?
any clue c0mm0n ?
Regards
mgf_braila
Posted: 2004-11-24 21:29:36
It doesn't seem like the links for the MSI Btoes driver works, and neither does the other links.
Can someone help me out on this one, since my MSI Btoes doesn't work as it should with the newest software from MSI?
Thanks in advance.
Posted: 2004-12-03 10:00:10
i have a usb device that says Bluetooth Dongle BT100 and i want to make it work with my pc and my bluetooth phone, but i have no drivers. I tried to find on the net but it's impossible. Does anyone knows where can i find them?
Posted: 2005-06-14 10:03:22
