Sony Ericsson / Sony : Software, Firmware and Drivers : (vFinal_rev5) AudioPhile Premium HD Acoustics for All A2 & UIQ3 Phones
@mrjulius,
of course! It's DB3150 right? Just try FLAT at first... If you don't like the manual equalizer, you can try your own eq, such as MegaBass, or edit customize_upgrade.xml to get your desired manual EQ
To all,
I have a plan to make acoustic for MPS speaker and MMC cable... Assuming that most of speaker out there has a poor quality... Maybe I should limit the dynamic range and make the channel tighter to prevent distortion at max volume... Then we could easily pumped up the volume while still minimizing distortion... But since I don't have MPS speaker and MMC cable (without testing, it could be worse), I can't promise this... Maybe I could do blind testing by using 3.5mm jack from HPM-77 and my old speaker
Quoted word above is only valid for beta version.
Hiron
[ This Message was edited by: Hiron on 2009-08-28 14:39 ]
Posted: 2009-08-23 17:32:09
So i just drag the file in ifs/settings/acoustics/
Also the cuztomize xml?
And i have mps 70 speaker so i can try your driver.
In your driver is eq uneditable?
Posted: 2009-08-23 20:34:22
@hiron
can i use your acoustic in my C905 and what should I do: flash it with one ****.zip or just uploud .csv and .PHF files
Posted: 2009-08-23 20:35:21
@mrjulius & x.men
Put *.csv too...it will make sound feels better.
Posted: 2009-08-23 23:03:13
@mrjulius,
MPS speaker is different... This acoustic doesn't has any effect on it
Extract the rar first... Then in a2uploader, select the desired "upload -*.zip." Press FLASH button instead of FS Tools.
My EQ uneditable? No. Read the first post again, I just updated it. Pay an attention especially since "Notes about customize_upgrade.xml in tpa/preset/custom"
@x.man,
Extract the rar first, then flash it with one ****.zip that you desired. Try 1. FLAT first.
For all people,
I have modified the first post to makes the rule about manual equalizer becomes more understandable. Pay an attention especially since "Notes about customize_upgrade.xml in tpa/preset/custom."
Hiron
Posted: 2009-08-24 01:35:12
@mr hiro
what happen if i use flash button
it's my first time to use the flash button
in FS i change my acoustic to w980 do i need to return the original one?
[ This Message was edited by: mrjulius on 2009-08-24 03:18 ]
Posted: 2009-08-24 04:17:27
On 2009-08-24 04:17:27, mrjulius wrote:
@mr hiro
Not Mr.....but Ms.....
Posted: 2009-08-24 08:00:37
@mrjulius,
If you add firmware files (*.mbn and *.fbn), it will flash the entire phone...
But if you only add the upload -*.zip files provided, it would just only access FS and automatically uploads the files to respective subdirectories. It's like uploading a custpack. Only 10 seconds.
You don't really need to use flash button. You can use "FileSystem Tools" and upload the PHF, CSV and XML manually. It's just that using flash button is more simple way without browsing your FS directories
Quoted word above only valid for beta version.
Use W980 acoustic? You don't need to upload the original. But if you would like to, it's okay
@sincan,
From se-indo.net?
Hiron
[ This Message was edited by: Hiron on 2009-08-28 14:37 ]
Posted: 2009-08-24 08:54:42
@boss hiron
so sir i just only drag the files and thats it and i will follow rules not to unplug headphones
Posted: 2009-08-24 09:35:55
not to unplug headphones? You can do that of course...
It's just advissed to not plug the handsfree while you play a music through loudspeaker... That's because the volume would be set to max for a while (0.2sec) through your handsfree... If you accidentaly wears that handsfree in your ears, you would get shocked
If you stop the music while plug the handsfree, that would be okay
Hiron
Posted: 2009-08-24 10:38:51
