Sony Ericsson / Sony : Software, Firmware and Drivers : (vFinal_rev5) AudioPhile Premium HD Acoustics for All A2 & UIQ3 Phones
@fastport is louder?
After investigating, 3.5mm jack uses different channel mixing, so it can behaves differently on the way it handles the sound. And 3.5mm jack also capable of handling more output power than fastport, hence contributing on the overall clarity
Do you still want the louder one?
Ok, by using this csv,
equalizer is limited to +/-3dB to minimized distortion.
Here it is: 21dB louder than original W995. Use at you own risk.
If you think that it's still not too loud, then I'm surrender
-- Link Removed --
Hiron
[ This Message was edited by: Hiron on 2009-08-28 13:59 ]
Posted: 2009-08-26 23:18:53
one question does the csv effect the phf and jack volume or the whole phone when in walkman player cuz when i put that loudest.csv and removed the headset there was some serious distortion o and it gave it nice boost from the headset and you may not like this part
its still not as loud as the w810. I know it may sound ridiculous but its just how it is, you gave it a nice shot and thank you for that
Posted: 2009-08-27 11:18:36
The csv doesn't affect the whole phone.. It's only used in media player/walkman when using handsfree/bluetooth.. If you use File Manager to play the music, it doesn't has any effect.. But if you want, I can make csv for File Manager and Loudspeaker..
If you suddenly remove the headset while playing a music, it takes some time for a phone to switch the mode.. Since I had raise the input signal, it will produced short distort.. That's normal
omg.. I surrender
Raising it furthermore will result in distortion.. I don't know, maybe it's limited in main, or could be hardware limitation
And btw, I'm retiring from acoustic modding world for a while.. I don't have any further idea..
Hiron
[ This Message was edited by: Hiron on 2009-08-27 14:11 ]
Posted: 2009-08-27 15:09:13
What are these values in the original?
Posted: 2009-08-27 15:56:07
What do you mean by default?
Each value controls 5-band manual equalizer, but it's untested in clear audio phones. All default is 0. You can set it to plus or minus value
Hiron
[ This Message was edited by: Hiron on 2009-08-27 15:39 ]
Posted: 2009-08-27 16:37:42
Hiron
Thank you so much..
Posted: 2009-08-27 18:05:28
Sennheiser CX-500 test.. Really very good driver.. No distortion.. Best best..!!
Max value 14?
Posted: 2009-08-27 18:48:56
No. K850 default is 15, but I may be wrong.. You could edit manual equalizer, or use Bass and MegaBass
You have K850? The csv may not work, therefore you don't get additional dynamic range and boosted (+6dB) volume. It depends on the csv
By using csv, I also can make the equalizer recognize more than 15dB/bar when using customize_upgrade.xml.. But only for phone that has csv
I'm glad hearing that you're satisfied
Hiron
[ This Message was edited by: Hiron on 2009-08-28 14:41 ]
Posted: 2009-08-27 22:53:42
@Hiron thank you for your comment..
Posted: 2009-08-28 02:38:01
Hi hiron I used your driver 'hard'. The sound quality is Wonderful. But doesn't have that much loud. Its decent.
I feel 3.5mm jack gives more 30% volume than fast port and quality also good with no distortion at t max. Why don't you do the change for fast port also.
[ This Message was edited by: idumbakumar on 2009-08-28 05:57 ]
Posted: 2009-08-28 04:56:24
