Sony Ericsson / Sony : Software, Firmware and Drivers : (vFinal_rev5) AudioPhile Premium HD Acoustics for All A2 & UIQ3 Phones
Ah, I see. So you did increase the values in the wbxml. I just think it's just my modification of my HPM-64.
Anyway, I did try it right away and got significant results. Got less bass but can still perceive your so-called Clear Bass experience.
My configurations (volume is set to 75 percent, Stereo widening turned on):
+10 0 0 0 +20
+10 4 6 4 +20 (2nd, 3rd, and 4th bar are based on what you suggested)
will experiment on other configurations and will post back here for feedbacks. I love experimenting my acoustic experience with your perfect driver. The thing is, your driver beats the iPod IMHO.
human voice? Raise the 4th bar as it amplifies voice.
Posted: 2010-06-05 18:30:00
On 2010-06-04 13:03:53, Hiron wrote:
@trojan001,
Amplified version has a lower volume compared to Normal... Try normal version...
If you still want to use amplified, set the eq to +14 +4 +6 +2 0
@all,
rev5 is up... the volume is increased a little bit because of trojan001's complain
Hiron
Hiron ok thank you very much!! i will try.
Posted: 2010-06-06 09:49:40
@Hiron
I feel the stereo on VXFinal is more widen than VX3 on DB3150 phone when I use HPM-77.So,the bass reduce...
What's the difference between VXFinal and VX3 on DB3150 acoustic? I think the VX3 is better now.
Posted: 2010-06-06 13:03:22
@Xfirfpxf, check pm for some interesting stuff
Posted: 2010-06-06 17:03:09
now testing it on this eq:
0 +4 +6 +4 +20
stereo widening on and using amplified. It's a good thing sometimes to lessen the bass.
Will try the normal version when I got time.
Posted: 2010-06-06 17:27:00
+20 in 16kHz freq?
Amplified version already has the treble amplified to +6, so the total is +26 if compared with Normal acoustic... Pretty extreme
Posted: 2010-06-07 11:40:47
wow! I don't know that!
then my ears are pretty extreme and weird, aren't it?
My configuration now:
MegaBass, Stereo widening OFF.
I simply like it than before in vX3!
Posted: 2010-06-07 14:13:00
Will use the latest revision on W715 with Sennheiser CX-300 and HPM70/64. Can't really compare with older versions though as I'm no audiophile. I'll try my best
Posted: 2010-06-08 06:16:40
Sounds good so far with Normal and recommended settings in the equalizer.
There is one thing that I don't like though, and it's the loudness from your CSV files. You said that the volume isn't modded, so why is it that with your CSVs, they sound louder than stock CSVs? I've been curious about this as you said that I can use your WBXML files with the original CSVs, resulting in a hit in audio quality.
Posted: 2010-06-09 00:12:38
i'll make a special csv for you.. Sorry i always forget to do this
Posted: 2010-06-09 03:57:03
