Sony Ericsson / Sony : Software, Firmware and Drivers : (vFinal_rev5) AudioPhile Premium HD Acoustics for All A2 & UIQ3 Phones
All rights, thanks. I'll gladly report back once you finish. Take your time with it
So you're saying that you did increase the volume in both the WBXML and CSV files?
Posted: 2010-06-09 05:40:47
I used this:
http://forums.se-nse.net/topic/49784-a2-clearbass-equalizer/
Can you recommend me a appropriate setting? Thanks!
Posted: 2010-06-10 12:54:03
Hiron
Thanks for these even better acoustic drivers.
Please help me out as I need more bass..
I have C510 n ur amlified final version acoustic and also patched with the clearbass patch.
I use Sennheiser CX180.
Thanks in advance...
Posted: 2010-06-28 07:50:26
@geokilla, yes, both of them increased
@boy.in.pink, for clearbass with Normal version, I recommend max clearbass, then all others set to 0 (flat)
@rajneesh,
special version sent. check your PM
Hiron
Posted: 2010-07-02 07:47:16
@Hiron
You Rock!!
Thank You So Much!!
Tried them and found them perfect to my requirement.
[ This Message was edited by: Rajneesh17 on 2010-07-02 19:49 ]
Posted: 2010-07-02 11:45:46
Hiron
Well this is what I made on my G502 with HPM-64:
Full ClearBass | +3 | -3 | -3 | -3 | +3
(or sometimes, the (5th/16kHz) highest range is set to 0 or +2)
Pretty extreme, isn't it. Anyway, with my Aiwa NSX-S20 Digital Audio System, I used this setting:
Full ClearBass | +1 | -3 | -3 | -3 | 0
Posted: 2010-07-07 10:31:51
I'll test your V Final soon.
I don't need more loudness than with the stock .csv files, so I'll use the stock .csv files and because of that I've got a question:
Do the .csv files affect the audio quality and the bass?
Posted: 2010-07-07 15:12:05
This music i can play with classic guitar.
Musical Instruments[ This Message was edited by: guitarlover on 2010-07-26 16:04 ]
Posted: 2010-07-26 17:03:52
I'd like to try the "normal" setting. Will this work on ELM?
[ This Message was edited by: xclbr on 2010-08-05 10:14 ]
Posted: 2010-08-05 05:57:19
HIRON can you make a more louder version for ELM?
Posted: 2010-08-12 19:57:09
