Sony Ericsson / Sony : Software, Firmware and Drivers : (vFinal_rev5) AudioPhile Premium HD Acoustics for All A2 & UIQ3 Phones
DOES This item work on ma c510 ??
Posted: 2010-09-18 18:59:44
if I flash new firmware, is this mod is erased? do I have to re-patch it again?
Posted: 2010-09-19 03:52:06
Hiron - you have new drivers for Aino?
Posted: 2010-09-19 04:35:43
Excellent drivers. One of the best I've used for A2 phones.
Posted: 2010-09-27 15:03:00
Yes it work on C510 as it is db3210.....
Yeah after flashing all the file system is re-stored so you have to copy these acoustic again
[ This Message was edited by: Rajneesh17 on 2010-09-28 09:47 ]
Posted: 2010-09-28 10:44:43
On 2010-09-14 07:14:43, Hiron wrote:
Elm In-Call Acoustics
Only for Elm. In-call volume increased. I made this because I had an Elm some times ago
Don't try it on the other headsets because I never test it other than Elm
[ This Message was edited by: Hiron on 2010-09-14 06:15 ]
How do I upload this one sir? through Far Mngr + sefp2 plugin?
if yes..
1. In what folder in my elm should I upload it?
2. Do I have to upload an empty customize_upgrade.xml together with it?
Thanks
Posted: 2010-09-30 11:06:32
excellent. lively. using it on hazel. thank you sir.
Posted: 2010-09-30 18:51:42
can i use this driver on my Elm ????
Posted: 2010-11-19 18:29:08
Hiron is using an Elm.
Posted: 2010-12-13 10:44:25
I need help installing this on W960i. I tried to copy PHF_2_play.aat, PHF_4_play.aat, and PHF_play.aat to C:\\private\\10200B19\\AATFiles\\ but I only found phf_1_play.aat, and phf_2_play.aat. Is there anything to rename? Thanks!
Posted: 2010-12-13 15:01:56
