General discussions : Product reviews : Sony Ericsson Aino review - after 48 hours of examination
General discussions >
Product reviews
Muhammad-Oli Posts: > 500
I should be able to test that in a few days. I'll let you all know when I get mine.
Posted: 2009-10-15 22:08:50
That would be great. Thanks
Posted: 2009-10-15 23:50:13
On 2009-10-15 00:19:20, midget wrote:
Now you've had this a wee while how long does the battery last? I've looked about but no reviews have mentioned battery life - only the 15 day standby time which is pretty useless in real life. You had to charge it much?
I'm using it quite a bit, for music when going to and from work. Also running the Tracker app in the background at the same time. Playing games every now and then, and taking pictures and videos.
I'm getting at least 2 days life from the batteries. I'd say it feels like twice the lifetime my Nokia N82 and HTC Dream gives me.
The test went from one morning where it was 93% charged, till the evening before the second morning (so almost two days) where it had about 13% left. And the phone had been used quite a lot in that period. So I'm satisfied.
Posted: 2009-10-16 06:52:11
the only thing that annoys me with this phone is you need to open the slider to browse the menu!
Posted: 2009-10-16 08:01:26
Yes there should been some buttons where u can when the slider is closed do some basic stuff etc..
Posted: 2009-10-19 16:03:36
The phone works nicely, quite happy with it at the moment. Tried the remote play funcion through my home wifi and it works fine. Didn't manage to connect to my PS3 through 3G or other wireless network. Need to work on that. The media player is great and I like the touch screen on the camera as well.
Just updated the firmware to newer version an wondering what is the changelog? ? ?
Posted: 2009-10-22 14:16:57
@SAiLO
Hi, what firmware is it?
Mine is R1BA049
Posted: 2009-10-22 18:01:13
mr lou - can you text using the touchscreen instead of the buttons? how is the touchscreen itself? can you use the screen to go into menus and stuff?
Posted: 2009-10-24 00:24:05
No you cannot. I wouldn't want to either. (If so, buy Satio).
I find the touchscreen to work fairly good. It has frozen on me 5 times so far, fixed with rebooting the phone. But it can be troublesome when using the camera.
No you cannot use touch to enter menus. Touch is only available in the media-menu and in Java apps that support touch, such as Opera Mini. If you want full touch, go with Satio.
Aino is for another target group, for people like me who doesn't really like touch that much.
Posted: 2009-10-25 19:31:17
hi
does anyone on here have a w995?
i am after the Aino or w995
but its too difficult
i am looking for a SE that does good video recordings as well as picture
as long as the quality is clear and good that will do.
and another thing
could someone please give me the measurements of the Aino and W995 when they are both slided up? as in opened
thanks a lot
Posted: 2009-10-29 17:21:45
