Sony Ericsson / Sony : Tips and tricks : Free Browsing With PC & Fone as Modem
< Esato Forum Index > Sony Ericsson / Sony > Tips and tricks > Free Browsing With PC & Fone as Modem Bookmark topic
Page <  12345678>
litemint Posts: 252
no prob anig, the link is here
Posted: 2009-10-28 10:59:56
anningg Posts: 78
litemint,hey thanks for the link but it doesnt load on my phone but i will keep trying
Posted: 2009-10-28 16:36:00
Leodusme Posts: 25
On 2009-10-23 09:14:02, krazyhaxx wrote:
Req:
* JRE (Sun Java Runtime Enviroment)
* JWT ( Sun Java Wireless Toolkit v2.5.2)
* Install both apps on PC/Laptop & use JWT enviroment to run ur OM Modded apps or Bolt v1.5 with same tricks as discussed.
* Also go to Sitnet's Post about similar Topic. Go to >> http://www.esato.com/board/viewtopic.php?topic=177634#post2813344
Good Luck!
Hi. I fail to get it running. I download the wireless toolkit, and java runtime. Wireless toolkit opens, but I can't put my Opera mini and Bolt to load from there...it won't allow to create a jar file. Only jad. Please help.
Posted: 2009-11-01 07:30:00
krazyhaxx Posts: 34
@Leodusme -> Get JADMaker & use it to generate jad files from jar files. Just make sure u put the .jad & .jar files in the same folder before running the jad app.
Posted: 2009-11-02 04:45:04
krazyhaxx Posts: 34
Posted: 2009-11-02 05:05:54
Leodusme Posts: 25
Thank you I finally got Bolt to open on my PC...
But I'm having trouble connecting it to the internet. I keep on getting the error "Internet not available. Check network services"
Although I am connected to the internet. Please help me sort it out thanks.
[ This Message was edited by: Leodusme on 2009-11-03 08:27 ]
Posted: 2009-11-03 09:09:00
krazyhaxx Posts: 34
@Leodusme - What kind of connection are u using 2 connect yo fone 2 pc (Bluetooth, USB Cable, etc).
Did u create yo connection manually or are u connecting via a fone management software like Nokia PC Suite?
Posted: 2009-11-03 12:17:15
Leodusme Posts: 25
@krazy - i'm connecting using one of those 3G Vodafone Modems. But I also do have Nokia PC Suite with the connectivity cable. But what difference would it make?
[ This Message was edited by: Leodusme on 2009-11-03 15:34 ]
Posted: 2009-11-03 16:29:00
anningg Posts: 78
@all,hey guys has any had any progress with connecting phone to pc as modem using opera 10 or any other web browser with the tricks?
Posted: 2009-11-08 15:05:00
Cyborg_a0 Posts: 283
What i know is just connect ur phone to your pc using usb data cable, if the pc already detected your phone,
open your Nokia Pc Suite
click Connect to the Internet
a window will pop-out
One Touch Access
click setting
select Manual
input your APN
leave the username & p.w blank
finish wait until it says connected
then goto your pc browser
IE,firefox,opera or whatever
edit its proxy setting
if your using cellc,
you can apply ip trick the same to your phone.
Ex.
Proxy address: smokeflower.com
port: 80
then browse
www.mxit.co.za/dahr.php
if your using vodafone
use your default ip in the proxy address
then browse:
live.vodafone.com.1h1.net
or this
live.vodafone.com.myproxy.ca
Posted: 2009-11-08 15:30:00
Page <  12345678>
