Sony Ericsson / Sony : Tips and tricks : Free Browsing With PC & Fone as Modem
< Esato Forum Index > Sony Ericsson / Sony > Tips and tricks > Free Browsing With PC & Fone as Modem Bookmark topic
Page <  12345678>
VANILLA_ICE Posts: 19
On 2009-11-20 08:48:00, Cyborg_a0 wrote:
@krazy
gud4u bro, try also
live.vodafone.com.layyit.com
1h1.net has dowload limit.
I don't know the dowload limit of layyit, but i tried 40mb and it download.
@Cyborg, I tried layyit.com but takes very long to load the page.
Posted: 2009-11-20 09:28:00
krazyhaxx Posts: 34
@Cyborg & Vanilla - I've also tried using the layyit.com proxy and it is rather slow. I'll try using it just 4 downloading and see what happens.
One thing I've also been experiencing is the issue of bittorrenting via proxy. I juss can't seem to get this to work no matter what i try. I've downloaded all the apps from acquered's thread but i'm failing to get those to work as well.
Does any of you guys know any solution to this. I urgently need a patch for fl studio 9 for educational purposes.
Posted: 2009-11-20 13:21:00
liesperit Posts: 16
@litemint..i have followe your intsruction but i can connect to internet..
it is the airtime cause such a problem i.e i cant connect to the internet...
or because of expired date airtime...
anyone can helps me...
i really appreciate your kindness...
Posted: 2009-11-26 06:29:58
krazyhaxx Posts: 34
Hi All!
Pls hlp me wit dis problem:
{ WARNING: SSL not supported, entering non-anonymous area!
The proxy as installed does not support SSL, i.e. URLs that start with "https://"... }
This issue makes it impossible 4 me 2 browse any site using SSL encription i.e. gmail.
Is there any way around coz i really need 2 access these sites.
Regards
Posted: 2009-11-26 09:57:31
kayoKasee Posts: 1
In your firefox network setting, use other proxy like hoseface.com in port 80.
In the address bar:
live.vodafone.com/images/index.php
or
live.vodafone.com/dahr.php
I hope this helps.
Posted: 2009-11-28 06:20:00
Cyborg_a0 Posts: 283
@kau xe
well they already done that bro, the result is just an error.
Posted: 2009-11-28 08:56:00
anningg Posts: 78
@cyborg,it works on cellc and i havnt tried it yet on mtn and vodacom
Posted: 2009-11-28 11:15:00
@anning
yes it will work with cellc but in vodacom i think it wont work
[ This Message was edited by: Cyborg_a0 on 2009-11-28 10:54 ]
Posted: 2009-11-28 11:44:00
btw
here another php proxy for downloading big files
for cellc and mtn
proxy add: piingschool.info
port: 80
bookmark:
http://mxit.co.za/index.php
i forgot the freesite of mtn
just bookmark in this format
http://freesite/index.php
Posted: 2009-11-28 11:51:00
anningg Posts: 78
@cyborg,will try them now and let you know...ow yes mtn's freesite is im.mtn.co.za
Posted: 2009-11-28 12:39:00
Page <  12345678>
